Compensation for Bass and Baritone
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=11420
Author:  j.Brown [ Thu Mar 29, 2007 3:15 am ]
Does compensation for acoustic basses and baritones generally need to be same, less than, or equal to a standard steel string?
Do string tension and string size both play a part in that?
What do some of you use as a general rule?
-j.
Author:  j.Brown [ Thu Mar 29, 2007 4:17 am ]
Now that the excitment of John Watkins' contest has died down, is there anyone out there who can answer this?
-j.
Author:  Dave White [ Thu Mar 29, 2007 4:32 am ]
J
There was this previous post.
For baritones I need more compensation - particularly on the base strings - but others may build a different way. This is the picture in the other post that is not showing:
Author:  TonyKarol [ Thu Mar 29, 2007 8:38 am ]
On 28-29 inch scales, using the 16-70 Daddario set, I set the bridge slot leading edge forward 1mm for the high B, and set the centre of the slot at about 5mm for the low B. I also use a 3/16 saddle on bari's, so there is more room to move around the break point at the saddle.
