It is currently Fri Jul 18, 2025 5:38 pm
PostPosted: Thu May 10, 2007 2:43 am
Anyone know of a supplier for small pots to use for soundhole volume control? I am looking for something I can stick on the soundboard just inside soundhole;  adapting to existing USL type pickup.  Around 20K-ohm should do.   I know many acoustic pickup suppliers sell these as a unit with their pickups but haven't found a source for the discreet component.    Any help is appreciated.  Thanks,  Dave
PostPosted: Thu May 10, 2007 2:53 am
Allparts or WD should have something like that. If not, I'd check Radio Shack.
PostPosted: Thu May 10, 2007 3:03 am
A little OT but
although I dont think you can buy them (only have them installed by an authorized Taylor dealer) but the expression system p/u setup is unbelievable! I had a Taylor 714ce with the first expression systems that were installed, boy they sounded fantastic, even though the guitar never really opened up the plugged in sound was amazing.
I wish there was a commercially available version of this system - just a couple little wafer thin disks attached to the underside of the top and a few non-intrusive knobs sticking out on the sides, beside the neck, brilliant and very discreet.
Charliewood
PostPosted: Thu May 10, 2007 3:58 am
Check Mouser.com they have a mind numbing catalog with every electronic part known to man. Bring aspirin.
best, Evan
PostPosted: Thu May 10, 2007 10:05 am
Thanks Evan,   mouser.com looks like a great resource; thanks for the tip.  Dave
PostPosted: Thu May 10, 2007 11:58 pm
I believe CE Distribution has what you are looking for
CE dist. They even have the Marshall bias pots that NO ONE seems to ever have.
PostPosted: Fri May 11, 2007 1:39 am
First name: Nelson
Last Name: Palen
MOUSER
What Evan said.   The thumbwheel pots might be a good configuration to mount inside the soundhole but I don't see any 20K.
Can't say enough good about Mouser. No minimum charge and very quick delivery.
Nelson
