...and things were going so smoothly! http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=11985 |
Author: | Chris Cordle [ Fri May 11, 2007 12:52 pm ] |
Post subject: | |
Things were going so smoothly with #3 and I was just starting to feel really good about my progress until...... This would have been a good thread to go in the stupid mistakes topic a short while back.... I was so concerned with getting my headblock glued and positioned properly that I forgot to cut the length and angle for the back! ![]() The bad thing is I didn't realize it until I went to profile my sides for the back and realized the block was 4 inches deep and I had already installed the kerfing for the top. I was able to recover, however. It set me back about 2 hours of meticulous work. To correct myself I began by using a Dremel with a cut- off blade to begin cutting away the excess (at least I was smart enough to have scribed my lines on the block before gluing). I made several relief cuts then began chiseling out big chunks of mahogany. When I got it somewhat close I proceeded with profiling my sides getting the headblock area as close as possible. Then with the sides out of my way for the most part I was able to put some 80 grit on a piece of oak and begin sanding in the proper angle. I eventually was able to get it all squared away again, finished with profiling the sides and installed my back kerfing. All is well........for now ![]() |
Author: | WaddyThomson [ Fri May 11, 2007 4:58 pm ] |
Post subject: | |
Oh the misery! Oh the ingenuity! Sounds like you have it all in hand. Congratulations. |
Author: | hogan [ Fri May 11, 2007 9:07 pm ] |
Post subject: | |
I also make mistakes. Oh yea. Really |
Author: | Jim Kirby [ Fri May 11, 2007 10:41 pm ] |
Post subject: | |
Yes, there are always bigger mistakes to make (see my recent comments about having to take the back off a classical guitar in a thread on fish glue disassembly - it helps to set the neck properly BEFORE the glue has dried ![]() ![]() |
Author: | peterm [ Sat May 12, 2007 3:13 am ] |
Post subject: | |
Chris, we all do them sometimes!Just keep taking notes, it helps in the future... |
Author: | CarltonM [ Sat May 12, 2007 6:44 am ] |
Post subject: | |
Whew! Yep, good save! |
