It is currently Wed Jul 23, 2025 5:24 am
PostPosted: Mon Mar 07, 2005 11:43 am
State: ON
Well this is what I have to show for 5 hours of work today (most of which was spent setting up my router to cut the rosette channel and wooden circle). This is my first attempt at making a rosette using wood and shell. Snake wood and Paua abalone is the combination here. My standard rosette is wood and this is what I have decided to offer as an upgrade. This is the first time I have used the shell strips for anything and I am very pleased with the results. If the rosette isn’t pretty enough then you should see this top and the back and sides! Bearclaw Engelmann spruce on a nice set of Cocobolo. Can’t wait to get this one done.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Mar 07, 2005 12:01 pm
Schweet! Looks like a lot of work!
I Love the snakewood!
Nice Job Josh!
PostPosted: Mon Mar 07, 2005 12:09 pm
Hey Josh....
Really nice!!!!
It's a winner...I'll take one,2,3.
Thanks for sharing
Walter
PostPosted: Mon Mar 07, 2005 2:39 pm
State: ON
Thanks guys. Its really not that hard to do. I think now that I have done one I should be able to cut my time significantly. Probably down to 1 hr or less.The big job was setting up my router. But now that it is done I will not have to do it again.
josh
Josh House
PostPosted: Mon Mar 07, 2005 2:55 pm
I like it, I like it.
PostPosted: Mon Mar 07, 2005 3:13 pm
State: BC
ya two thumbs up. that looks great
CVT Inc.
PostPosted: Mon Mar 07, 2005 3:16 pm
[QUOTE=Josh H] If the rosette isn’t pretty enough then you should see this top and the back and sides!
Josh
Not to worry, Josh. That's just beautiful. Where did you snag the snakewood?
PostPosted: Mon Mar 07, 2005 11:29 pm
State: ON
I am using the snakewood rosette pieces from LMI. It took me two pieces to do that rosette. I can get away with only using one on my standard 1/2 in. rosette. I would like to buy a large piece of snakewood and cut my own pieces but it is so expensive. So I will probably continue to get it from LMI until I can find another source that will sell it in small quantities.
josh
Josh House
