V-joint on a steel string?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=12269
Author:  crich [ Thu May 31, 2007 7:22 am ]
Does anyone use the V-joint on a steel string? CLinton
Author:  Alan Carruth [ Thu May 31, 2007 8:05 am ]
Yup.
Because of the way it's loaded the tension of the strings actually pulls it tighter. As long as there's enough area on either side of the V to take up the remaining shear loads it will hold fine. I've used V joins as a repair technique when the head is broken off somewhere up in the middle and the break is not clean enough to simply glue back together. I've even used V-joins on 12 strings. Stay within normal proportions any you'll be fine.
