Grain and glue-ups http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=1231 |
Author: | Darin Spayd [ Sat Mar 05, 2005 9:56 am ] |
Post subject: | |
Which of the following is the proper grain orientation for say a neck lamination or heel block? ![]() |
Author: | Darin Spayd [ Sat Mar 05, 2005 9:59 am ] |
Post subject: | |
Oooops! Forgot to space between the images. ![]() |
Author: | Dickey [ Sat Mar 05, 2005 10:55 am ] |
Post subject: | |
Top or middle, either one, for a neck lay up. Heel block, dunno, never done one of those? |
Author: | Bob Steidl [ Sat Mar 05, 2005 11:32 am ] |
Post subject: | |
Your best bet is to arrange the laminations with the outer edge of the tree along the center, like this: )))))|((((( I think that's the first image you posted. |
Author: | Don Williams [ Sat Mar 05, 2005 11:38 am ] |
Post subject: | |
I do believe Bob is right... |
Author: | Don A [ Sat Mar 05, 2005 12:51 pm ] |
Post subject: | |
Great question Darin. I've wanted to try some laminated necks myself, other than buying from BobC ![]() |
Author: | Dickey [ Sat Mar 05, 2005 4:18 pm ] |
Post subject: | |
The reason I said either.... you can't control it in a neck. Why, you ask? I use sixquarter material and cut it from a slab eight inches wide. Each layup makes two necks, so if there is a curve, it usually comes together at the heel of one blank, but less so on the opposite blank. Hard to visualize, but I'll try: 1. A plank of flatsawn mahogany approx 1 1/2 " by 8 " 2. The plank cut in two pieces with best match of grain. 3. Top neck of the blank 4. Bottom neck of the blank grain is reversed. Fairly simple. I usually like one end better than the other each time I do a glue up. But the main thing is that they equally conteract the grain of the opposite piece to which their glued. Plus, mahogany is just pretty stable wood regardless of how it's cut or glued. Gibson loved to take three one inch slabs, glue 'em up and make a neck. |
Author: | Bob Steidl [ Sun Mar 06, 2005 4:26 am ] |
Post subject: | |
I suggested using pieces arranged so that the outside of the tree in the center for stability reasons; they are least likely to delaminate in that arrangement (think about the way a board will cup as humidity changes and the pressure on the glue line). I think Al Carruth suggested this and it makes sense to me. Bruce, I agree that in most cases it will not matter much; and given the way in which you make your laminations, you may not have much choice. I make my necks differently and cut a board's worth of individual laminates, then match them up. Benedetto's approach. |
Author: | Dickey [ Sun Mar 06, 2005 6:21 am ] |
Post subject: | |
I don't have the benefit of Benedetto. And the other source for me, Hoffman, uses solid 3 by 4 inch blanks, rips them in half, flips both halves and reglues to gain opposing stress counteraction. Fairly simple. The wood locally available is 6/4 or 1 1/2 ". Now it seems I'm without a local source for Honduran and may have to go another route for necks anyway. I'd be happy to listen to a description of Benedetto. |
Author: | npalen [ Mon Mar 07, 2005 7:29 am ] |
Post subject: | |
Where are the trees you guys keep talking about? (center of the tree) I must not be able to see the trees for the forest. ![]() Nelson |
