It is currently Thu Jul 17, 2025 9:57 pm
PostPosted: Mon Jun 04, 2007 1:16 am
First name: Blain
City: Leander
Just wondering what the approximate shelf life of shellac is once you dissolve the flakes in Alcohol.
Blain
http://www.ullrichguitar.com
PostPosted: Mon Jun 04, 2007 1:42 am
Dependent on how it is stored, heat and humidity I would not use after 60 days. Better to mix no more then you need per project.
That said I don't mix from flakes often. I use Zinzzer's Bulls Eye Seal Coat pre-mixed sealer because I like the tint of it and it has a 3 year shelf life per Zinzzer. However I seldom keep it more than 6 or seven months
PostPosted: Mon Jun 04, 2007 4:20 am
First name: Blain
City: Leander
Thanks Michael.
I had some that I mixed up to practice with a while back, but I think it's beyond the 60 days.
I've heard a lot about the Zinzzer's pre mixed stuff. I might have to give it a try.
Blain
PostPosted: Mon Jun 04, 2007 4:55 am
Hey Michael,
So, am I correct in thinking that you're using the Bullseye sealer as a final shellac finish?
I bought a can of it to see how well it would fill grain. Tested it out on a piece of Spanish cedar and brushed on three coats. Didn't do all that well as a filler, but it did have a decent gloss I'll admit.
Another question. Do you brush it on or use a pad?
Best,
Michael
Live to Play, Play to Live
PostPosted: Mon Jun 04, 2007 5:08 am
[QUOTE=Michael McBroom] Hey Michael,
Best,
Michael
I Zpoxy fill or on occasion pumice fill Seal Coat worked fine for pumice fill. I would not use just shellac to fill pores Any shellac will tend to bridge pores due to its viscosity. They may appear filled but later sink.
I have done brushed on final finishes, I have done sprayed on Shellac final finishes. But mostly French polish for final finishes and padded on seal coats
PostPosted: Mon Jun 04, 2007 5:25 am
By the way the problem really is not the shellac but the solvent. If you could 100% dehydrate the mixed shellac and store it in dry air tight container you could reuse it but to leave it in mixed form the alcohol goes bad and absorbs moister from the air. Even in a well caped squeeze bottle moister will infiltrate the the bottle and contaminate solvent.
PostPosted: Mon Jun 04, 2007 5:49 am
Has anyone ever tried that stuff that you are supposed to be able to put in paint cans to keep paint from skimming over?  Seems like that (I assume it is heavier than air, and sits on top of the liquid in the container) might work to keep air and moisture away from the alcohol.  Just wondering out loud.
PostPosted: Mon Jun 04, 2007 5:54 am
My guess is the alcohol would desolve it
PostPosted: Mon Jun 04, 2007 6:47 am
First name: Blain
City: Leander
One thing that I just thought about the Zinzzer's shellac that probably isn't an issue, but just striked me as interesting...
Don't they say that shellac isn't supposed to come in contact with Metal because it could alter the chemical properties and cause it to not dry properly?
The Zinzzer shellac comes in a paint can which is metal of some sort right? I'm sure they know what they're doing otherwise they wouldn't be selling the stuff, but I wonder what the difference is...
Blain
PostPosted: Mon Jun 04, 2007 6:50 am
The insidee of the can is coated.
PostPosted: Mon Jun 04, 2007 6:52 am
where is Leander? I thought I knew where almost everything in Texas was
PostPosted: Mon Jun 04, 2007 7:46 am
[QUOTE=MichaelP] where is Leander? I thought I knew where almost everything in Texas was [/QUOTE]
Look here:
http://www.ci.leander.tx.us/index.cfm
Sounds kinda nice.
Best,
Michael
PostPosted: Mon Jun 04, 2007 8:00 am
Heck I have hopped all around the Austin area and never noticed Leander, But I have to admit that I could have been impaired
PostPosted: Mon Jun 04, 2007 8:39 am
First name: Blain
City: Leander
Cool, thanks Michael. I guess if I actually went out and bought a can, I'd see that.
Yes, Leander is just outside of Austin (North West).
If you're familar with Cedar Park, it's just North of Cedar Park on 183. The area has been growing a lot within the last 5 years.
If you're ever in the area, let me know. I know of some good places to get impaired.
Blain
PostPosted: Mon Jun 04, 2007 8:42 am
[QUOTE=blain1976] Cool, thanks Michael. I guess if I actually went out and bought a can, I'd see that.
If you're ever in the area, let me know. I know of some good places to get impaired. [/QUOTE]
Careful Blain I am likely to do just that
PostPosted: Mon Jun 04, 2007 4:06 pm
First name: Blain
City: Leander
Ha ha. Come on down.
Maybe you could even show me a thing or two about buildig guitars (before getting impaired of course.
Blain
