Binding/Purfling questions http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=12354 |
Author: | Ray Pepalis [ Wed Jun 06, 2007 10:50 am ] |
Post subject: | |
I am planning to use wood bindings .250" tall by .080" to .082" wide, and BWB purflings .093" tall by .058" to .060" wide. I will use the purflings on the top, back and sides. I have the LMI set of router bearings, but don't know which to use with my router/binding jig. Any suggestions? Also, should the purflings on the top and back be glued in separately, or all at once with the bindings? Thanks, Ray |
Author: | SniderMike [ Wed Jun 06, 2007 11:05 am ] |
Post subject: | |
Ray, some people glue them in all at once, but that's too much for me. I like gluing the purflings in first with CA glue. Just be sure to seal the edge of the top with shellac so the CA doesn't wick into your top. |
Author: | SniderMike [ Wed Jun 06, 2007 11:07 am ] |
Post subject: | |
By the way, stewmac makes a nice li'l bottle of medium CA with a brush attached to the top, like nail polish. It has worked great for me. |
Author: | Ray Pepalis [ Wed Jun 06, 2007 10:14 pm ] |
Post subject: | |
Michael, Doesen't the Titebond stick to the PVC? Thanks, Ray |
Author: | Ray Pepalis [ Thu Jun 07, 2007 1:39 am ] |
Post subject: | |
So, my question boils down to this: Since the LMI bearings provide purfling ledges in increments of .010", and my purfling widths are between increments - shall I choose the bearing set that "forces" the purfling, or the set that allows for a gap? Can I expect that the purflings will swell to fit the overly wide ledge? Thanks, Ray |
Author: | Wayne Clark [ Thu Jun 07, 2007 1:52 am ] |
Post subject: | |
You should be able to get the depth of the ledge closer to the width of the purfling by wrapping a layer of tape around the bearing. You want purfling to fit tight between the top and the binding. The purfling might swell a little from the moisture in the glue, but you don't want to depend on that to fill a gap. |
Author: | Brock Poling [ Thu Jun 07, 2007 1:53 am ] |
Post subject: | |
In that situation I sand my bindings to match the rabbet. If you use one that is slightly too small and sand your bindings a little more you should get a perfect fit. |
Author: | peterm [ Thu Jun 07, 2007 1:57 am ] |
Post subject: | |
Ray, I add about .010 to conpensate for swelling of the bindings and purflings... if using wood glue. |
