Redwood tops http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=12489 |
Page 1 of 2 |
Author: | pakhan [ Mon Jun 18, 2007 3:59 am ] |
Post subject: | |
Hi Guys, I was wondering apart from Lance K, who had worked with a lot of redwood tops? More curious than anything! Warmest Regards, Terence www.goodacoustics.com |
Author: | JB Dickey [ Mon Jun 18, 2007 4:40 am ] |
Post subject: | |
Hank has used his fair share. I've done more processing redwood tops than building. It's a tricky wood. The more beautiful the flaming, the more likely in billet form it is to get surface checking, rendering it useless for guitar tops. Who needs built in trouble? I purchased some really straight nice stock from LMI and it seems to be well quartered and stable. While I think some really nice guitars have successfully been built with it, it's problematic wood for the short and long term. It's so soft, that looking at it mars it, it seems. And then when a real test comes, like something dropped on a top, well, it's bad, similar to western red cedar. Those are typically and historically woods used on classicals. We see many builders using it now for steel string, but I for one, am convinced that for longevity spruces are a little better choice. That said, one of my favorite players has strummed a cedar top for 25 years, having now retired that guitar from the road. The new one.... a cedar top. So, redwood may work for many, just fine, but as you can tell, I'm a skeptic. How are things in Europe? |
Author: | LanceK [ Mon Jun 18, 2007 5:10 am ] |
Post subject: | |
I certainly dont want to disagree that Redwood is softer or less dent resistant than spruce. But, its not nearly as soft as cedar. What I see as the biggest difference in redwood vs cedar is its propensity to split, and its brittleness. That brittleness is probably what give it is depth and shimmering highs, unlike cedar which tends to be warm. Now don't get me wrong, I love cedar too! ![]() |
Author: | pakhan [ Mon Jun 18, 2007 5:10 am ] |
Post subject: | |
[QUOTE=JB Dickey] Hank has used his fair share. How are things in Europe? [/QUOTE]Man, I forgot about Hank, and Dennis! Things are cool. Plugging away, but may take a job in south east asia later this year... |
Author: | Andy Zimmerman [ Mon Jun 18, 2007 5:42 am ] |
Post subject: | |
I have used redwood and I like it. But, redwood is extremely week across grain. But fairly strong in its longitudinal stiffness. (Similar to cedar) If you flex the wood horizontally (Side to side) It can snap very easily so be careful. Tonally it is a bit warmer than spruce, but still balanced. I think of it as a balance between cedar and spruce. Here is my most recent redwood top. I thicknessed it to 0.113. based on deflection testing. Keep in mind, my tops are generally thinner than most tops ![]() |
Author: | LanceK [ Mon Jun 18, 2007 6:04 am ] |
Post subject: | |
Andy, I was at Tonys this weekend and seen one of your beautys hanging in the white room, right next to Heshs sweet Koa creation! |
Author: | LanceK [ Mon Jun 18, 2007 6:10 am ] |
Post subject: | |
Oh yeah, there was also two of John Kinnairds great looking guitars, and a few others that will remain nameless unless they want to speak up. Some I'm sure that will be on display at HGF. |
Author: | pakhan [ Mon Jun 18, 2007 8:06 am ] |
Post subject: | |
[QUOTE=Hesh1956] I agree with everyone..... ![]() Like Andy I see redwood as sounding in between cedar and spruce and like Lance I agree that redwood has beautiful, shimmering highs. ![]() ![]() That's my assessment too! Warmest regards, Terence |
Author: | John Mayes [ Mon Jun 18, 2007 8:26 am ] |
Post subject: | |
I've built around 30 or so redwood topped Mayes Guitars. and a couple dozen redwood topped ukes.... Love redwood for ukes... |
Author: | McCollum [ Mon Jun 18, 2007 1:04 pm ] |
Post subject: | |
I think I've built around 60 redwood tops,I have a few opinion's, Oh and 3 failurs,all from the same source! Lance |
Author: | Blanchard [ Mon Jun 18, 2007 1:23 pm ] |
Post subject: | |
I pretty much agree with the previous posts, but..... I think redwood is one of the hardest woods to generalize about. It's density ranges from as light as cedar to as heavy as the heaviest Adirondack. Stiffness, in both directions is all over the map. Even from the same tree, redwood sets can be quite different. Maybe it's because the trees are so big. I have a couple of sets of LS redwood that seem to be from different zip codes !! Evaluate each set individually when deciding if it is right for a particular guitar. Mark |
Author: | Hank Mauel [ Tue Jun 19, 2007 2:41 am ] |
Post subject: | |
[QUOTE=JB Dickey] Hank has used his fair share. I purchased some really straight nice stock from LMI and it seems to be well quartered and stable. [/QUOTE] That would be the redwood I supply to LMI...from the same stock that I have sold direct to fellow OLF'ers and other luthiers. All the straight grain tops I have ever built with are still doing fine. The flamed stuff, as mentioned by Lance elsewhere, has caused some problems...mainly through abuse of the instrument. That said, I would use the flamed sets for either double top acoustics (Peter M.is doing that) or overlays on a solid/semi acoustic electric. Longevity...I don't think any of us will liove long enough to see/hear one "play out" or go dead. As with any instrument, care and maintenance are in order. |
Author: | JB Dickey [ Tue Jun 19, 2007 5:12 am ] |
Post subject: | |
I love this thread. Now this is the OLF at it's finest. |
Author: | pakhan [ Tue Jun 19, 2007 11:20 pm ] |
Post subject: | |
Here's a wierd question... what have you used to brace redwood tops? I've built 1 redwood topped guitar and I used sitka, cause that was all I had! Warmest regards, Terence |
Author: | LanceK [ Tue Jun 19, 2007 11:28 pm ] |
Post subject: | |
Adirondack. |
Author: | Dave White [ Wed Jun 20, 2007 12:04 am ] |
Post subject: | |
[QUOTE=pakhan] Here's a wierd question... what have you used to brace redwood tops? I've built 1 redwood topped guitar and I used sitka, cause that was all I had! Warmest regards, Terence[/QUOTE] Hey Terence, You've made a guitar - fantastic ![]() |
Author: | zac_in_ak [ Wed Jun 20, 2007 3:15 pm ] |
Post subject: | |
[QUOTE=John Mayes] I've built around 30 or so redwood topped Mayes Guitars. and a couple dozen redwood topped ukes.... Love redwood for ukes...[/QUOTE] Redwood Ukes? Pic please John! ![]() in case you havnt noticed I am a Uke lover and You make some nice ones John Sorry for the hijack ![]() |
Author: | pakhan [ Fri Jun 22, 2007 2:51 am ] |
Post subject: | |
Hi Dave, it was one of the few I built back in high school- nothing to shout about but I'll see if I can dig out the photos. I would describe the build quality as agricultural! Warmest regards, Terence www.goodacoustics.com |
Author: | peterm [ Fri Jun 22, 2007 4:14 am ] |
Post subject: | |
I'm building two semi double tops with it! Great stuff! ![]() ![]() |
Author: | John Mayes [ Fri Jun 22, 2007 8:04 am ] |
Post subject: | |
[QUOTE=zac_in_ak] [QUOTE=John Mayes] I've built around 30 or so redwood topped Mayes Guitars. and a couple dozen redwood topped ukes.... Love redwood for ukes...[/QUOTE] Redwood Ukes? Pic please John! ![]() in case you havnt noticed I am a Uke lover and You make some nice ones John Sorry for the hijack ![]() Ok here are a couple of many... ![]() ![]() |
Author: | John Mayes [ Fri Jun 22, 2007 8:05 am ] |
Post subject: | |
lets try that last one again.... ![]() |
Author: | Blain [ Fri Jun 22, 2007 8:21 am ] |
Post subject: | |
May I ask what types of backs and sides all of you are using when building with Redwood tops? |
Author: | Don Williams [ Fri Jun 22, 2007 8:52 am ] |
Post subject: | |
Wow, John Mayes, you build some great instruments there friend. I really like your work. Peter, I finally have to 'fess up and admit my ignorance about double tops. Would you consider showing us what's involved in making one so that this dummy can understand it? Thanks.... |
