Help Identify Import Jointer http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=12800 |
Author: | joe white(old) [ Wed Jul 11, 2007 7:33 am ] |
Post subject: | |
I need a little help with a jointer I found at a local industrial auction. It is an import (Taiwan) but very clean. I don't think it is very old. It is medium olive green and the id tag reads; Northwood (in red letters) It is labeled model CT-150D and it is a six inch. Its a one horse and has the cabinet style base. I have already tried it out on some cedar 1x6 I had laying around and it cut great. I'm sure it will be more than adequate to get tops and backs ready to join and I want to get new knives/blades for it but I can't find any info on it so far. I can post a pic if needed. Anyone have any info for me? |
Author: | Steve Saville [ Wed Jul 11, 2007 7:49 am ] |
Post subject: | |
Joe, Do not use that on your tops and backs! It will destroy them. |
Author: | JohnAbercrombie [ Wed Jul 11, 2007 7:51 am ] |
Post subject: | |
[QUOTE=SteveS] Joe, Do not use that on your tops and backs! It will destroy them.[/QUOTE] Jointing the edge of top/back plates on a power jointer works just fine. Now, if the OP had suggested putting backs through a thickness planer.... John |
Author: | JohnAbercrombie [ Wed Jul 11, 2007 7:54 am ] |
Post subject: | |
Joe- There are a lot of machines out there with different nameplates, but most of them are knockoffs of Delta/Rockwell machines, made in Taiwan. Unless the blades are quite unusual, you can probably find replacements by just using the dimensions of your existing blades. If you use a sharpening service, a question to them might get you results quickly. Cheers John |
Author: | JohnAbercrombie [ Wed Jul 11, 2007 7:59 am ] |
Post subject: | |
Try- http://www.westernapex.com/pdf-files/Bladesnbits-Com-Planer- Jointer-Blades.pdf |
Author: | WaddyThomson [ Wed Jul 11, 2007 8:00 am ] |
Post subject: | |
Joe, I did a Google search on Northwood Jointer, and got a link to what was, apparently, one of Northwood Tools' more popular items, a 6" jointer. They are an Australian Tool Company, and still have a website, but I couldn't find a jointer on the site. Probably something they had in the past, that they had their name put on. I noticed, that another site was selling blades that would fit Grizzly and Northwood jointers. Apparently they also have a Store in the US now too. Maybe they would have some answers for you. |
Author: | joe white(old) [ Wed Jul 11, 2007 9:40 am ] |
Post subject: | |
Thanks guys! I messed around with it a little more and found that the old owners had the fence set up in such a way that the first one inch of the 6 inch blades weren't ever used. I set it up to make use of that and got a very clean and precise cut. I also removed one of the blades and measured so I can find replacements. Wouldn't sharpening these be pretty tricky? seems that they would have to be pretty accurate from one blade to the next. I do have a lot of Amish craftsmen and sharpening services in my area, maybe I could give that a try? Steve, you really mean not to use a jointer to create a clean and straight edge to join the two sides of a back or top? I thought this was an acceptable ( and controversial?) method? |
Author: | JohnAbercrombie [ Wed Jul 11, 2007 9:55 am ] |
Post subject: | |
Joe- You should be able to get several sharpenings out of a set of jointer blades- replacing them isn't necessary very often. I just keep a second (sharp) set on hand and swap them out when needed. Some jointers let you shift the blades sideways a bit; this can be handy if you get a 'nick' in the blades- shift one and you can get a reasonably smooth cut until you swap out the set. There are also techniques/jigs for honing blades yourself, but I usually just get them sharpened professionally. If you ask some of the local craftsmen, they should steer you to a good sharpening service. Some of the 'sharpening' services can't be trusted with anything but lawnmower blades. I found a bunch of CT-150 jointers on the web-perhaps like yours- they look like nice machines. I think the CT refers to the company in China that makes them. Cheers John |
Author: | Steve Saville [ Wed Jul 11, 2007 10:57 am ] |
Post subject: | |
[QUOTE=joe white] Steve, you really mean not to use a jointer to create a clean and straight edge to join the two sides of a back or top? I thought this was an acceptable ( and controversial?) method? [/QUOTE]Evidently some are successful at doing that. That's great and perhaps you will be good at it. I use a shooting board and block plane. I have a nice 6" jointer and I wouldn't use it for that. I'm not saying I'm right and they are wrong. There are many ways to do it. Some use a straight block with sandpaper and are very successful. I think I saw one gut using a table saw. |
Author: | crazymanmichael [ Wed Jul 11, 2007 2:27 pm ] |
Post subject: | |
if i was to choose between using a block plane or my jointer to join plates i would take the jointer any day. whilst i did try it once with a block plane it found it too short. the shortest plane i've been pleased with for the purpose was a no 4 smooth with the iron honed square, but my favourite is a no 5 jack. some prefer to use 6's and 7's. even read about a chap who used a no 8. |
