Use of Backing Board on Power Planer http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=12859 |
Author: | Ricardo [ Mon Jul 16, 2007 9:10 am ] |
Post subject: | |
Has anybody tried using a backing board to plane thin stock? My 12.5" Delta planer goes down to 1/8". If I put the stock on a 3/4" piece of plywood will this work or will the planer eat it? Should I double stick tape it down or will the pressure of the rollers suffice? |
Author: | A Peebels [ Mon Jul 16, 2007 9:20 am ] |
Post subject: | |
I have used a backer board and double sided tape for thicknessing backs and sides with some success, however I strongly recommend not using this method. It really gets ugly when a strip of rosewood explodes and throws chunks all over the shop. It's hard on blades as well. If you can't afford a thickness sander right now, check the local cabinet shops and see if they can do it for you. Otherwise a safety planer and a random orbital sander will get you by untill you can get a thickness sander. Al |
Author: | Ricardo [ Mon Jul 16, 2007 9:26 am ] |
Post subject: | |
My first attempt at using a safety planer was a bit intimidating. My Grizzly 14" Drill press has a maximum speed around 3200. I see that the recommended speed is between 4,000 and 6,000. Maybe I try planing by hand. |
Author: | Ricardo [ Mon Jul 16, 2007 12:10 pm ] |
Post subject: | |
OK thanks, I'll give the safety planer another go. |
Author: | Michael Dale Payne [ Tue Jul 17, 2007 12:37 am ] |
Post subject: | |
I have to admit to have been one of those that thought I would save $800 and use a Safety planer forever and forgo as long as possible investing in a drum sander, I finally broke down and bought one, actually two. I have had mine now for maybe 4 months I have to say I should have bought them years ago. One is 16-32 and the other a 10-20. For the hobbyist luthier a 10-20 is probably good enough And it can be bought for less than two LN hand planes. A drum sander really is the best tool for thicknessing tonewood. If you don't have one my advise is get one or two. ![]() |
Author: | Ricardo [ Tue Jul 17, 2007 1:56 am ] |
Post subject: | |
Michael, I agree. I spent several hours setting up my drill press for the safety planer. I got better cuts than in the past, but it still cuts with a shredding action on spruce, and this is a new safety planer. So I will bite the bullet and buy the Performax 10-20. I know its going to be really useful. Thanks ![]() |
Author: | WaddyThomson [ Tue Jul 17, 2007 2:05 am ] |
Post subject: | |
The key to good "Safety Planing" is sharpen and make sure the blades are seated in a plane with no burrs, and evenly ground. Could take some set-up time with the planer, probably not more than 15 minutes though. There is a thread on this in the archives. |
