I'm working on three bass necks for a customer. Upon removing a neck and all the hardware for a re-lacquer job using amber tint, I notice the gears are horribly loose. All of them.
These are off a Fender type Mighty Might neck. The tuner has Japan made into the casting. They have pressed in bushings on the topside and four screws attaching them from behind.
Here is the odd thing, the post wiggles side to side one sixteenth of an inch or about 2 MM. I removed a screw holding the gear and there is round hole with two flats to make the shaft turn the gear. I can flip the gear over and it completely tightens the gear onto the shaft. However it seems a bit tight.
Okay, any bassheads out there that know what I'm experiencing. I'm not sure the guy who put this bass neck on put the gears together wrong. I want to know for sure. Thanks.
