Martins OM X-bracing plan http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=13836 |
Author: | James Orr [ Sun Sep 30, 2007 8:07 am ] |
Post subject: | |
Hi everyone Does anyone know where I can get the bracing layout of an actual Martin OM? I'd like to get my hands on it to study a bit from the original. Angles and placement. Thanks for any leads! |
Author: | Don Williams [ Sun Sep 30, 2007 8:47 am ] |
Post subject: | |
John Hall has plans. So does Stew Mac I think. GAL almost certainly would. |
Author: | James Orr [ Sun Sep 30, 2007 8:52 am ] |
Post subject: | |
Thanks Don. I just want to be sure I get one that is as close to what Martin's using as possible rather than an interpretation of it. |
Author: | James Orr [ Sun Sep 30, 2007 11:19 am ] |
Post subject: | |
Thanks, Todd. That's exactly what I was hoping for. In this case, I just have the desire to look at the Martin to see the basis for most of the bracing patterns out there. MichaelP did the OLF OM plans, and Michael is an excellent builder and illustrator. The finger braces look a bite more acute than the Martin, so I'm not sure if anything else is varied. |
Author: | Michael Dale Payne [ Mon Oct 01, 2007 12:34 am ] |
Post subject: | |
The location of the top bracing on the OLF OM is is a direct descendant of the bracing pattern that was drawn on the top provided with a Martin OM-14 kit I bought direct from Martin and built years ago, but only in reference to brace locations. I lighten up the bracing some. Martin has re-designed there A-Frame bracing several times since the 40's I believe the OLF OM plans reflect the current design, but I could be wrong there. |
Author: | Kevin Gallagher [ Mon Oct 01, 2007 10:25 pm ] |
Post subject: | |
Martin's "A" frame bracing a the neck block was designed and implemented for the very first time in the early 90s. I was there to be a part of that design team. The "X" bracing has been around for decades, but the "A" portion is brand new. You can call Gail at GMC (Guitarmaker's Connection) at Martin and she will trace the actual OM pattern placement onto a poster for you. That way, you'll know that you're getting what is, in fact, the Martin pattern and not a close facsimile. Regards, Kevin Gallagher/Omega Guitars |
Author: | Dave White [ Mon Oct 01, 2007 10:47 pm ] |
Post subject: | |
[QUOTE=Kevin Gallagher] Martin's "A" frame bracing a the neck block was designed and implemented for the very first time in the early 90s. I was there to be a part of that design team. The "X" bracing has been around for decades, but the "A" portion is brand new. [/QUOTE] Kevin, It's fascinating to know that you were part of the Martin design team that "birthed" the Martin A brace. I'd love to know more about how the concept evolved and took shape. Part of my interest lies in UK guitar making "folklore". I have heard that Roger Bucknall of Fylde guitars and George Lowden have been using "A" frame upper bout braces that are set into the neckblock since the early 1970's in their instruments. I say "heard" as I haven't spoken directly to either of these great builders about it. So many guitar "innovations" are developed in isolation but when you look around in either time or geography, the same innovations are occuring without any direct knowledge or contact between the people involved - Morphic Resonance I think you would call it and a fascinating example of human evolution. Pardon my rambling . . . ![]() |
Author: | Colin S [ Tue Oct 02, 2007 12:21 am ] |
Post subject: | |
Dave, I had one of Rodger's guitars in the late 70s and it did have the A frame at the neck block, and I believe George beat him to it as well. It's the same with the X- brace, Eustaquio Torralba made guitars that effectively used an X brace and a single upper harminic bar in the 1860s. Martin's design evolved to carry out the same function, so took a similar form, X-brace and single upper harmonic bar. One type of co-evolution. It's the same in evolutionary biology where animals from different genera say, sharks and dolphins evolve the same general shape because they are adapting to the the same enviornment. Very little is truly new, most things and designs are simply evotionary steps in a developing continuum. People talk about things being a quantum leap, well a quantum is a very small amount! Colin |
Author: | Kevin Gallagher [ Tue Oct 02, 2007 1:31 am ] |
Post subject: | |
The evolution in guitar design is a pretty far stretch from the theory of evolution in nature, but there has been an evolution of sorts, nonetheless. In most cases where a design shows up that was used by another...or several other builders...in the past, the new innovator was directly influenced by those original designs. This continues to happen today with very well known ideas of one builder showing up on the guitars of others within weeks of their introduction. There are those exceptions where a new idea comes from nothing less than creative innovation, but most come from copying an idea in an effort to build off of it as a foundation for growth. I've seen some "X" braced guitars that were built long before old C.F. Martin ever laid his hands and tools to wood and I'd seen several "A" braced guitars before the idea ever hit Nazareth, but both ideas have become widely credited to Martin simply because of theirhigh level of visibility. The Martin theory behind the "X" brace was not only to take advantage of the structural support offered by the long legs of the "X" braces, but also to transport vibration to the nodal portions of the vibrating top or to transduce those areas into active conributors to the tone of the guitars. The "A" bracing or hybrid design takes advantage of the longitudinal strength of those quartersawn braces as they're applied in a more paralel configuration in relationship to the top's grain and the tension generated and applied by the strings. Regards, Kevin Gallagher/Omega Guitars |
Author: | James Orr [ Tue Oct 02, 2007 3:47 am ] |
Post subject: | |
Hey, thanks for the conversation, guys! Michael, sorry about the incorrect reference there. I'd like to create a few facimiles of tops based on what I know about them. When we talk about bracing, it seems to come down to making the top as resonant as possible, which isn't a bad thing. That's also how Rob Schenk talked about it in an interview he did in the latest issue of Fingerstyle Guitar. It seems like there's another side to it though. Some guitars have lots of note to note separation, some have an interesting character in the overtones, etc. Some of that has to come from positioning. I've noticed that guitars with lots of separation tend not to have parallel lower face braces. The lower of the two seems to be pointed a little more towards the lower bout than the top---but that's as far as that assessment goes on my side and I have no idea if it does anything to the tone at all. I'm really interested in simply gathering information about guitars I like to see if I notice any patterns in the build AND the character of the guitar. |
Author: | James Orr [ Wed Oct 03, 2007 5:45 am ] |
Post subject: | |
Gail is going to send me a reject top with the bracing pattern traced on. Thanks, Kevin. It will be interesting to see what they send. |
Author: | Kevin Gallagher [ Wed Oct 03, 2007 11:15 am ] |
Post subject: | |
James, No thanks necessary. Gail is a great lady and she will go the extra mile to make you happy and to get the right parts into your hands. I pop in there every now and thn to say hello and to flip through woods and things of interest that may be on hand. I take the Martin tour once or twice a month and snap a few hundred photos of everything new under the roof and usually get to slide in to sit with the R&D guys for a little discussion on design and tooing and finish...or whatever happens to be the hot topic of the day. The Martin plant is still one of the finest guitar building facilities on the planet...and most of what makes it so cool are the great people working there. From Chris Martin down, they are a friendly bunch. Regards, Kevin Gallagher |
