Finish Cracking Technique http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=13891 |
Author: | Dave-SKG [ Thu Oct 04, 2007 2:19 am ] |
Post subject: | |
Anyone got a good techique for cracking finishes? I believe I once heard Dan Erlewine talk about using one of those computer air cleaner cans and opening it up directly on the finish. Seems like that would be an expensive way to do a whole guitar. I think Tom Murphy used to paint them on for a while...that's too tedious for me. Some one else said to toss the body in the freezer...I think he was joking. Anyway, My customer wants their brand new finish, I just sprayed nitro, Cracked. Any Ideas? TIA |
Author: | Dave-SKG [ Thu Oct 04, 2007 2:20 am ] |
Post subject: | |
P.S. This is an electric guitar - a tele. Finished in Black Nitro. |
Author: | DannyV [ Thu Oct 04, 2007 2:30 am ] |
Post subject: | |
Sounds like a job for Martha Stewart. You might try asking a dedicated paint store that knows there products well. I know there is some faux finishing technique out there for that look. Good luck, Danny |
Author: | Marc Lupien [ Thu Oct 04, 2007 2:45 am ] |
Post subject: | |
I heard that some people "designed" the cracks using an exacto knife... Yep, one at a time!!! And then, to give them an aged look (for example on a cream finish) dirty oil was rubbed in the cracks... |
Author: | JohnAbercrombie [ Thu Oct 04, 2007 4:43 am ] |
Post subject: | |
The freezer idea is not so far-fetched. Years ago, I did a 'free repair' on a cheap guitar with a heavy sunburst. I didn't know what I was doing, but at least I didn't ruin anything valuable. Attempting to match the dark sunburst color (black) with tinted lacquer, I applied many coats over a few days. It looked great- thick and glossy, just like from the factory. The owner (kid brother of a friend) put it in the trunk of his car and drove it to Timmins, Ontario (up north) in January - this was before global warming had kicked in. He was moving, so he left it in the car for a few days before bringing it inside. The lacquer was a mass of crackling- absolutely amazing in depth and extent. Unfortunately, it wasn't really the effect he was after ( in those days -70s- we called 'em 'beat-up and abused' , not 'relic'd'....), and I stopped doing repairs- even feeebies. On a serious note, I noticed that the TwelfthFret guitar shop in Toronto has a note about winter shipping and cold damage, as well. Cheers John |
Author: | SniderMike [ Thu Oct 04, 2007 4:48 am ] |
Post subject: | |
Dry ice. There's also at least one big name guy (can't remember who) who does use an exacto knife. I've not tried either, but I've seen pretty good results with dry ice. |
Author: | Dave-SKG [ Thu Oct 04, 2007 4:57 am ] |
Post subject: | |
Mike, how do you apply the dry ice? I would assume, perhaps wrongly so, that direct contact would "burn" the finish. Perhaps in a cooler to bring the temp below freezing? |
Author: | Dave-SKG [ Thu Oct 04, 2007 4:58 am ] |
Post subject: | |
Thank you all for your input. |
Author: | SniderMike [ Thu Oct 04, 2007 5:06 am ] |
Post subject: | |
Dave, I really don't know. Sorry! |
Author: | David Collins [ Thu Oct 04, 2007 6:46 am ] |
Post subject: | |
Any extreme and rapid temperature change will crack the finish - canned air sprayed upside-down, pulling from freezer to warm room, dry ice (or plain old wet ice for that matter). The problem is it will leave you with a random crackle pattern that bears very little resemblance to a natural crazing. The only way I've found to get an accurate crazing is by etching in each individual line by hand with a razor or Xacto. You can make a half dozen templates to to follow, running a few consecutive lines of the same template, then switching to another, spacing them somewhat sporadically. Then etching in some random lines coming from hardware and screw points, or diverging from the template lines and following just parallel for a shorter distance. You just really have to try to mimic the lines of an existing natural crazing of a similar model if you have one to reference. Then a relatively light blast of the canned air cold will crack the finish along those lines, adding in more minor accent cracks between them. Too much cold at this point can just spiderweb the whole thing though. Then sometimes buffing or hand rubbing off the harsh etched edges, rubbing some nose grease and dust from a bookcase, etc. There's no hard rules and definitely no easy shortcuts to hand etching that I've every found for a natural crazing look. Many of today's lacquers are also working against you. They generally have a much higher plasticizer level than stuff used in the 50's and 60's. Mohawk used to make a lacquer sold as "production lacquer", or "industrial lacquer" that had very low plasticizer and was wonderful for touching up and replicating old finishes. It's hopefully still available under the Star/ Mohawk/Behlen/Valspar merged conglomerate today, but I'm not sure. It's still certainly doable with other lacquers, but they don't check quite as easily. Mike, it's probably Tom Murphy you're thinking of that's well known for his hand etched crazing. That's who I learned it from, and though I've tried plenty of other techniques I've yet to find one that works as well. |
Author: | Bob Garrish [ Thu Oct 04, 2007 7:06 am ] |
Post subject: | |
In a thread a couple weeks ago Mario said he really loaded the lacquer on a guitar and it crazed by itself in just a few months. |
Author: | SniderMike [ Thu Oct 04, 2007 7:17 am ] |
Post subject: | |
Yes, David - Tom Murphy is exactly who I was thinking of. Thanks. |
Author: | Dave-SKG [ Thu Oct 04, 2007 8:07 am ] |
Post subject: | |
David, Thank you for the info. I met Tom Murphy about six years ,or so, ago, and he explained his technique to me...it just didn't seem to make sense back then...the etching part...but now it does...sort of stress relief cuts like the concrete guys do. I am going to give it a try...I am sure the guy is going to like it no matter how it turns out...I told him I was going to let my dog chew on it as well... to get some good gouge marks. That reminds me...does anyone know what Fender used to spray as a primer...color wise...I have seen some cracked older instruments and they look like they had a layer of white or yellow in there somewhere. THANKS SO MUCH FOR ALL YOUR HELP! |
Author: | erikbojerik [ Thu Oct 04, 2007 9:07 am ] |
Post subject: | |
[QUOTE=Dave-SKG]That reminds me...does anyone know what Fender used to spray as a primer...color wise...I have seen some cracked older instruments and they look like they had a layer of white or yellow in there somewhere.[/QUOTE] I think that would be fullerplast. Whatever it was... ![]() +1 on the hand-etching. If you look at vintage Les Pauls, Teles/Strats and acoustics, you'll find three very different crazing patterns. The Fenders tend to craze along the grain, the LPs across the grain, and the acoustics more randomly from points of stress on the tops. And none of them match the effect you get from those quickie cold-blast treatments (which IMO looks more like a rock-through-a-window kind of pattern). |
Author: | David Collins [ Thu Oct 04, 2007 11:40 am ] |
Post subject: | |
Right, Fullerplast was the brand of base coat / sealer they were using at the time, though today it's always used as a generic term for that Fender yellow. There's debate as to whether the Fullerplast sealer even contained the color or was simply clear sealer, and differing accounts of how it was applied, but that's another story. The yellow was applied on all early bodies whether they were a burst or not, with the exception of Mary Kay or Olympic White guitars that were set aside. And since I'm short of a dog to chew on my finishes, I find a big ring of keys to be about the best chip/ding/dent utensil. |
Author: | tommygoat [ Thu Oct 04, 2007 3:02 pm ] |
Post subject: | |
An excellent site for Fender minutia. The link on custom colors has some good info that might interest some of you. www.provide.net/~cfh/fender.html |
Author: | David Collins [ Thu Oct 04, 2007 4:11 pm ] |
Post subject: | |
That site certainly has a wealth of good information (the author/host lives in a nearby town from my shop), but I remember there being a few discrepancies with the procedures he lists and those Hideo Kamimoto presented. Hideo is a very trustworthy and recognized authority on old Fender finishes, but I'd have to dig up my notes from a seminar about 10 years ago. The discrepancies may just be in my memory, or perhaps just different procedures from different eras. Either way, Clay's site is an excellent resource. |
Author: | tommygoat [ Thu Oct 04, 2007 5:36 pm ] |
Post subject: | |
Fender is one homespun funky universe. Nile Rodgers searched for years to find the origin of his strange old strat. Turns out it was probably shaped/finished by a guy who was taking work home to help with production. Apparently, a lot of things that went down back then are very hard to track these days? Certainly makes it more fun to reseach. |
Author: | David Collins [ Thu Oct 04, 2007 6:16 pm ] |
Post subject: | |
I worked on a '70 strat some time back that was probably a 4 or 5 piece body, veneered on the face and back, painted white, fake grain applied, then bursted. I know of a few others of lower models that have been documented from this experimental phase, but this was the only Strat I've seen. ![]() Fender finishes have a strange legacy indeed..... |
Author: | erikbojerik [ Thu Oct 04, 2007 10:28 pm ] |
Post subject: | |
[QUOTE=David Collins]I worked on a '70 strat some time back that was probably a 4 or 5 piece body, veneered on the face and back, painted white, fake grain applied, then bursted.[/QUOTE] If it was a Japanese Strat, that might be the dreaded "photo flame". Basically a layer of clear transparency with a flame pattern copied onto it, then veneered onto the front & back of the body. ![]() |
Author: | David Collins [ Thu Oct 04, 2007 11:32 pm ] |
Post subject: | |
No, this is long before Japanese Strats. This was a weird anomaly from California, presumably a short-lived attempt to get by with smaller, cheaper, less perfect boards. |
Author: | Evan Gluck [ Thu Oct 04, 2007 11:41 pm ] |
Post subject: | |
The foto flames were in the 90's I remember working at Sam Ash when they were blowing them out. There was something pretty sickening about seeing all those flame tops with the same grain ![]() Best, Evan |
Author: | tommygoat [ Fri Oct 05, 2007 4:24 am ] |
Post subject: | |
I have one of those Japanese foto flames in my shop. Heres a funny thing; if you look at the neck you can see an outline of the McDonalds 'Hamburgerlar' character repeated in the flame pattern. |
Author: | Evan Gluck [ Fri Oct 05, 2007 4:50 am ] |
Post subject: | |
Tom, I used to show people that as a sales pitch ![]() Best, Evan |
Author: | Dave-SKG [ Mon Oct 08, 2007 12:35 am ] |
Post subject: | |
Thank You everyone, for all the input/info. |
