It is currently Sat Nov 23, 2024 3:32 pm
PostPosted: Sun Oct 14, 2007 10:50 am
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
what are the top and back radius on a Martin D28 Dreadnaught? I was I check myself before I go any farther.
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Sun Oct 14, 2007 11:10 am
28' top, 20' back. Modern ones anyway.
PostPosted: Sun Oct 14, 2007 12:35 pm
I think you may be right on that Todd. I'm recalling that info from last time I
cared much about what Martin did, which was at least 10 years ago.
But really, now that you mention it 25' does sound right for the backs.
PostPosted: Sun Oct 14, 2007 12:53 pm
Todd has it right. 28/25 for D and 28/20 for smaller.
PostPosted: Sun Oct 14, 2007 1:01 pm
Last Name: Sterling
City: Ulster Park
State: New York
 So that is the size radius discs I need for this projects? I want to use the discs for sanding the kerfing and making the braces as well. Is there an easier way?
PostPosted: Sun Oct 14, 2007 1:15 pm
Bill, you can use a sanding board for the kerfing but the dishes are the easiest way for me. Look at the StewMac directions for building a sanding board. StewMac directions.
For the braces you can make a template and radius using a router with a pattern bit or plane or you can use the Brace Maker sold by Luthier Suppliers. Brace Maker.
If you plan to build more than 1 guitar the investment in dishes is well worth it. They are also good tools to glue the braces to the top/back and also the top/backs to the shell using a gobar deck.
PostPosted: Sun Oct 14, 2007 4:09 pm
Last Name: Mansfield
City: El Dorado Hills
Hey guys -
Is there a rule of thumb about how to apply an appropriate radius to designs.
I made myself a 15' and 30' dish for my last build (wasn't that hard, just took some math, some plywood, a router, some earplugs, a couple of hours' time, and a good shower afterwards).  The last build was an OM; now I'm planning something bigger (20" length and 16.25" width), but was planning on using the dishes I have.  Would different radii be more appropriate for a larger guitar?  How do you determine this?
Because, honestly, although the dishes weren't hard to make, I'd like to avoid the complaining from the wife about the noise...
PostPosted: Mon Oct 15, 2007 4:12 am
When I asked that question here a few years ago, I was told as a very general rule that the more dome the more projection, and the flatter the dome the more warmth.
