Saddle Slot http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=1405 |
Author: | Kelby [ Sat Mar 19, 2005 2:51 pm ] |
Post subject: | |
So we just strung up my son's guitar, and I ran into a problem I always seem to run into: As we add tension to the strings, the saddle tips forward at a slight angle. I can still adjust it in its angled-setting to proper intonation, but I hate the forward angle. Does anyone else have this problem, and how do you fix it? I was pretty careful to try to cut a slot that's the same thickness as the saddle, although I suppose there's always just a little wiggle room in there. |
Author: | Darin Spayd [ Sat Mar 19, 2005 5:19 pm ] |
Post subject: | |
I just found this topic in an old AG mag. article by Frank Ford. From what he said, I don't think you want to risk the life of the bridge. Maybe you could make a new saddle to fit the slot. |
Author: | LanceK [ Sat Mar 19, 2005 11:38 pm ] |
Post subject: | |
Kelby - there should be -NO- wiggle in the saddle slot, it should be a slight compression fit. I make mine so that Its possible but a little difficult to remove with your hand. Nice and snug -- |
Author: | Kelby [ Sun Mar 20, 2005 3:05 am ] |
Post subject: | |
Thank you both for your responses. I may have overstated things when I said there was "wiggle room," but in light of the comment that it should be a little difficult to pull out by hand, I should probably make it a little tighter of a fit. |
Author: | Sylvan [ Sun Mar 20, 2005 3:33 am ] |
Post subject: | |
I cut my saddle slot with about a 4 degree backward tilt. I have found that with a slight tilt the strings actually pull the saddle up nice and straight with no forward leaning at all. Works for me! |
