On my bench.... http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=14290 |
Author: | LanceK [ Mon Oct 29, 2007 10:59 am ] |
Post subject: | |
Here is something I have been working on lately. The back and sides are done, it on to the top now. It will be LS Redwood. This one will be ready for the Miami show. Thanks for looking! |
Author: | Andy Zimmerman [ Mon Oct 29, 2007 11:00 am ] |
Post subject: | |
As usual, very nice and AMAZINGLY clean |
Author: | LanceK [ Mon Oct 29, 2007 11:16 am ] |
Post subject: | |
Thanks guys, Hesh, I have never had any luck using reverse linings on cutaways. So that is why the standard triangle liners for this one. |
Author: | davidmor [ Mon Oct 29, 2007 11:28 am ] |
Post subject: | |
Okay, I have to ask as I have seen this several times and I just don't know the answer. What does the LS in LS Redwood stand for? |
Author: | LanceK [ Mon Oct 29, 2007 11:47 am ] |
Post subject: | |
Lucky Strike. If you search for it in the archives, Hank Mauel has a nice discription. |
Author: | LuthierSupplier [ Mon Oct 29, 2007 12:10 pm ] |
Post subject: | |
Just gorgeous Lance! Great job! Tracy |
Author: | L. Presnall [ Mon Oct 29, 2007 12:14 pm ] |
Post subject: | |
Mr. CLEAN! ![]() ![]() ![]() |
Author: | davidmor [ Mon Oct 29, 2007 12:23 pm ] |
Post subject: | |
[QUOTE=LanceK]Lucky Strike. If you search for it in the archives, Hank Mauel has a nice discription.[/QUOTE] Thanks Lance, I found it. I was pretty sure it was sinker wood, but I couldn't for the life of me figure out what the "L" stood for. Little did I know I had the "S" wrong too! |
Author: | WaddyThomson [ Mon Oct 29, 2007 12:30 pm ] |
Post subject: | |
Nice work, Lance, that looks great. |
Author: | JohnAbercrombie [ Mon Oct 29, 2007 12:41 pm ] |
Post subject: | |
Lance- Beautiful work! Too bad you picked such plain b+s wood! ![]() Pretty spectacular! Cheers John |
Author: | Bruce Dickey [ Mon Oct 29, 2007 1:21 pm ] |
Post subject: | |
Lance, You could've saved that wood for retirement! Nice Box and Curves! Miami, you may need it when winter hits there.... ![]() |
Author: | crich [ Tue Oct 30, 2007 3:23 am ] |
Post subject: | |
Very nice. Man,how do you get those kerf cuts for your braces so clean? ![]() |
Author: | LanceK [ Tue Oct 30, 2007 3:30 am ] |
Post subject: | |
[QUOTE=crich] Very nice. Man,how do you get those kerf cuts for your braces so clean? ![]() Thanks Clinton, its really not that hard, I just go at them one tuck at a time. Measure, re-measured and measure again just to be sure! Cut, measure again, when its perfect, I move to the other side of the brace end and repeat ![]() |
Author: | sbrunker [ Tue Oct 30, 2007 3:47 am ] |
Post subject: | |
Very nice, Lance! I haven't peeked into very many cutaway's. If you have time, can you describe the geometry of your neck block (why does it look the way it does? :-) It looks like part of the neck block is "floating" into the soundboard. I have some guesses as to what it accomplishes, but they're just guesses. |
Author: | Dave Anderson [ Tue Oct 30, 2007 3:52 am ] |
Post subject: | |
Very nice Lance. So clean and spotless as usual. |
Author: | LanceK [ Tue Oct 30, 2007 4:01 am ] |
Post subject: | |
Stuart, no real trickery there. The neck block and side from the center to the cutaway edge is the same measurement as my fretboard at the 14th fret center to out side edge. The block is wider on the top (non cutaway) side because that is simply the standard thickness of my blocks. I like the tongue to be a tad wider than the fretboard so that there is a strong bed for the board to lay on. |
Author: | sbrunker [ Tue Oct 30, 2007 5:23 am ] |
Post subject: | |
Cool. Thanks for sharing, Lance. |
