It is currently Tue Sep 16, 2025 12:16 am
PostPosted: Mon Nov 05, 2007 3:41 am
Hello,
I have completed my 1st binding install, sanded a lot and put a coat of shellac on the top for protection. I plan to start pore filling this evening. Will the shellac that has run down onto the sides affect the pore filling or cause any type of discoloration... ie. do I really need to sand it off before applying my epoxy pore filler?
thanks.
Here's a shot... you can see the runs at the near the neck joint.
Chris Oliver
Infinity Luthiers
...in the shop.
live every minute...
PostPosted: Mon Nov 05, 2007 3:47 am
Last Name: Abercrombie
Chris:
I'd definitely try to get the bulk of the shellac drip removed before putting on the epoxy.
Often a paper towel and alcohol will remove shellac, especially if it is fresh. It can also help to 'blend' out the shellac mark.
You could test a scrap with shellac and then epoxy to see if the shellac will show, of course. That might take a bit of time, but will give you a better answer than you'll get online.
Nice-looking guitar, BTW.
PostPosted: Mon Nov 05, 2007 3:50 am
Chris shellac sticks to epoxy very well unfortunately epoxy does not stick well to shellac.  I would sand the shellac off the sides prior to using an epoxy finishing resin and pore filling.  This would go for the bindings too on the top if they have open pores.
PostPosted: Mon Nov 05, 2007 3:51 am
Sorry John buddy I did not see your excellent post.
PostPosted: Mon Nov 05, 2007 7:05 am
We say it and we say it but nobody listens
Epoxy first shellac second
if you plan to pore fill with epoxy, do it before you seal the guitar with shellac. as epoxy does not adhere to shellac well.
PostPosted: Mon Nov 05, 2007 8:22 am
Michael,
No worries, I'm pore filling the back and sides with epoxy. The shellac on the top is to protect from the epoxy. Giving the ole' french polish a try up there.
c
Chris Oliver
Infinity Luthiers
...in the shop.
PostPosted: Mon Nov 05, 2007 8:39 am
Good, I did not mean to sound critical. I was actuall quoting one of my all time favorite radio charitures when I wrote "We say it and we say it but nobody listens" That would be Fiber Magee but I beat I am one of the few around here Oldenough to remember the Fiber Magee and Molly radio show.
PostPosted: Mon Nov 05, 2007 8:47 am
I think that's Fibber McGee & Molly.  I remember.  Also remember "The Great Gildersleeve".  If you haven't seen it here is a good link to "The Lost Episodes- Volume I".
PostPosted: Mon Nov 05, 2007 9:02 am
1-b 2b's what ever How about Mr Throckmartin Now I reall showing my age
PostPosted: Mon Nov 05, 2007 9:08 am
After this nostalgic interlude, we return you to the the original program, "pore filling q (pic)".
