It is currently Tue Sep 16, 2025 2:49 am
PostPosted: Sun Nov 11, 2007 11:01 am
If a kid who sprayed his "standby" guitar with Home Depot type enamel wants it "shiny" now, can I spray laquer over it and buff it out for him? Or is there a compatibility issue? It's a Squire Stagemaster...not expensive, and it doesn't look too bad right now, just flat as opposed to glossy...it'd be a favor to him and kind of a pain for me, but if it's possible to shoot it with nitro I suppose I'll do it for him...
PostPosted: Sun Nov 11, 2007 12:00 pm
Larry,
dip it in thin ca.
PostPosted: Sun Nov 11, 2007 3:57 pm
Traditionally, you can put enamel over lacquer but if you try to put lacquer over enamel it will attack the finish like paint stripper.
PostPosted: Sun Nov 11, 2007 3:59 pm
And, of course, it all depends on the definition of "enamel"...which is kind of like "varnish".   It could be practically anything.
PostPosted: Sun Nov 11, 2007 4:37 pm
Lacquer will eat up oilbased enamel! If he got it from HD then that's probably what your looking at! Enamel over enamel is OK!
PostPosted: Mon Nov 12, 2007 8:56 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
Try a polyurathane clear finish. I have done this when i was a young teen building my frankenstein strats built from parts. The poly worked well over the enamels that i used to buy from the Pepboys auto supply.
PostPosted: Mon Nov 12, 2007 10:41 am
Mike,
Poly as in "brush on"? If that's the case, I think I'll let him do it!
