Help needed to repair broken headstock. http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=14597 |
Author: | CraigSz [ Mon Nov 19, 2007 5:29 pm ] |
Post subject: | |
Craig.
Author: | K.O. [ Mon Nov 19, 2007 6:30 pm ] |
Post subject: | |
Frank Ford presents some methods, go to the index to look over other headstock repair and other info. |
Author: | K.O. [ Mon Nov 19, 2007 6:33 pm ] |
Post subject: | |
Oops I meant to link to the backstrap |
Author: | David Collins [ Mon Nov 19, 2007 6:42 pm ] |
Post subject: | |
Work some glue in and clamp it. You could use PVA, epoxy, fish or hide glue on that one, and any would be fine. Use common sense in making sure it fits together nicely, and removing any stray fibers that get in the way, dry clamp a few times to make sure it goes together well, then work some glue in and clamp it. Not much more too it than that. |
Author: | K.O. [ Mon Nov 19, 2007 6:46 pm ] |
Post subject: | |
I sometimes wonder if biscuiting under the back-strap is worth while or even advisable. |
Author: | CraigSz [ Mon Nov 19, 2007 9:24 pm ] |
Post subject: | |
I appologise for the quality of the pics. What cannot be seen is the bottom of the end of the truss rod through the opening of the break. There appears to be only a couple of mm of wood covering it. Is it worth trying to build up that area perhaps by gluing another thin piece of wood over it once the break has been glued? Thanks Craig.
Author: | David Collins [ Tue Nov 20, 2007 1:30 am ] |
Post subject: | |
[QUOTE=CraigSz] What cannot be seen is the bottom of the end of the
Author: | FishtownMike [ Tue Nov 20, 2007 11:55 am ] |
Post subject: | |
Taylor fingerjoints their headstocks on to the neck? I guess this is one of their budget guitars. |
Author: | CraigSz [ Tue Nov 20, 2007 12:49 pm ] |
Post subject: | |
Thanks K.O. and David for your help. I feel a lot more confident although working on someone elses instrument will take some getting used to. It is a Taylor 110 bottom of the range I think but the owner has become quite attached to it over the years. Thanks again Craig. |
Author: | Rick Turner [ Tue Nov 20, 2007 1:08 pm ] |
Post subject: | |
Taylor has apparently stopped making necks this way. It was ugly as sin (my opinion), and I saw quite a few that broke (fact, not opinion) because of bad gluing, insufficient finger length on the joint, etc. Of course, the rabid Taylor fans thought it was brilliant...but the drank the KoolAide, too, and now they're all gone... |
Author: | FishtownMike [ Tue Nov 20, 2007 2:36 pm ] |
Post subject: | |
I agree with you on that Rick. In my mind it reminds me of cheap wood counter tops. This is where this type of joint is used frequently. |
Author: | Bruce Dickey [ Tue Nov 20, 2007 6:02 pm ] |
Post subject: | |
I didn't know they'd quit using this fingerjoint. Hmmm. Learn something new every day. What are they now using? Scarf Join? I know they put their heel block on the neck blank using a couple of small steel dowel pins and glue. Pretty amazing. I've never seen one of these joins fail on a Taylor though, even online. I did watch Bob Taylor intentionally break about six necks on the NT Neck Video a number of years back. Hurt my soul to see him do that to those new necks. ![]() This neck should repair fine. Good luck Craig. If it doesn't work out, have Taylor send out a new one and bolt it right up. Sheesh, wonder how much that would cost? Half the price of the guitar I'm guessing. |
Author: | Dave Rickard [ Wed Nov 21, 2007 12:09 am ] |
Post subject: | |
Craig, I've done 4 of these in the past and like everyone else said they realy are easy as pie ![]() |
Author: | JimWomack [ Wed Nov 21, 2007 6:43 am ] |
Post subject: | |
[QUOTE=ToddStock]Unless you pointed it out, most Taylor owners did not even notice it...sort of like the putty, I guess.[/QUOTE] Jeez, how could anyone miss it. It's the first thing that caught my eye. Makes it look cheap... IMHO. On the other hand, looks like a typical headstock repair... good advice given here already. |
Author: | Bruce Dickey [ Wed Nov 21, 2007 7:12 am ] |
Post subject: | |
![]() You carpenter types know this join from buying trim. Paint or Stain Grade, anyone? |
Author: | Bruce Dickey [ Wed Nov 21, 2007 7:14 am ] |
Post subject: | |
This must be fairly new. Notice the tuners, not Grover. |
Author: | curtis [ Fri Nov 23, 2007 10:20 pm ] |
Post subject: | |
[QUOTE=David Collins]Work some glue in and clamp it. You could use PVA, epoxy, fish or hide glue on that one, and any would be fine. Use common sense in making sure it fits together nicely, and removing any stray fibers that get in the way, dry clamp a few times to make sure it goes together well, then work some glue in and clamp it. Not much more too it than that.[/QUOTE] perfect advice. if anyone hasnt seen Davids headstock repair jig i urge you to check it out - just do a quick search on the forum. i sprinkle a little bit of water in the headstock break before i apply the glue (obv water soluble glue!) and occaisionally blow the glue up inside with an air line to ensure a good application, although its not essential. The sprinkling of water helps the glue find its way up inside the wood through cappiliary action or osmosis or magik or something. i've been meaning to make Davids jig for months - in fact several of them...then you buy a house, then it needs this and that... |
