Who has good plans for parlor guitar? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=14645 |
Author: | Ricardo [ Fri Nov 23, 2007 7:48 am ] |
Post subject: | |
How different is a parlor guitar from a baritone uke size wise? The parlor has 6 strings vs 4 on the uke. ![]() |
Author: | Mark Maquillan [ Fri Nov 23, 2007 8:01 am ] |
Post subject: | |
There is a plan by Scott Antes out there that is pretty good. The forum says its overbraced and to keep that in mind when building it. I am probably going to use that plan for my next build. I have the wood for a parlor size set aside.
Mark |
Author: | Rick Turner [ Fri Nov 23, 2007 8:06 am ] |
Post subject: | |
There is nothing so instructive as drawing your own plans. |
Author: | Dave Livermore [ Fri Nov 23, 2007 8:08 am ] |
Post subject: | |
Rich, Thanks for this question. I'm planning for a parlor/smaller guitar for my daughter and would love to have a plan to go from. If you figure out how overbraced the plan is, I'd love to hear about it. Right now I'm planning on 1/4" braces. Does anyone know it that is an unreasonable assumption? DAVE! |
Author: | Allen McFarlen [ Fri Nov 23, 2007 8:09 am ] |
Post subject: | |
I've got the Antes plan and it's calling for 8 x 12 mm bracing, 24.5 scale and 12 fret to the body. Nice little guitar, but I would brace lighter. |
Author: | Wade Sylvester [ Fri Nov 23, 2007 9:13 am ] |
Post subject: | |
I agree with Rick. You should at least try to make up your own plan. There are so many pictures of bracing schemes and all for free. If you took some time and made some full-scale drawings, you would be surprised how easy it is to scale a bracing idea to a different style or size guitar. If you don’t trust your own instincts, than buy the plan and see how close you came. You will learn a lot more than building from someone else’s drawing. I happen to think making the plan is one of the fun parts of making guitars. Wade |
Author: | Andy Zimmerman [ Fri Nov 23, 2007 1:47 pm ] |
Post subject: | |
I totally agree with Rick. Start with the body shape you want. Or if you like one already made, copy the shape. The rest all is based on scale length. Based on that you know your exact bridge position. Then make your X's and what ever variations you want. I like most started from Antes plans, OLF plans etc. But know the only thing the same is the shape. The rest evolves with experience. |
Author: | FishtownMike [ Sat Nov 24, 2007 1:18 pm ] |
Post subject: | |
[QUOTE=Max1157] There is a plan by Scott Antes out there that is pretty good. The forum says its overbraced and to keep that in mind when building it. I am probably going to use that plan for my next build. I have the wood for a parlor size set aside.
Mark [/QUOTE]I have a couple of his plans and they are quite good. |
Author: | Ricardo [ Sat Nov 24, 2007 1:31 pm ] |
Post subject: | |
Whats the tuning on these parlor guitars? Would they be compatible with the tuning of a uke GCEA? Thanks ![]() |
Post subject: | |
Another question. Is there such a thing as a parlor guitar built like a classical? With nylon strings? |
Author: | FishtownMike [ Sat Nov 24, 2007 4:12 pm ] |
Post subject: | |
Parlor guitar are tuned just like a regular guitar. |
Author: | Ricardo [ Sun Nov 25, 2007 7:19 am ] |
Post subject: | |
Todd this looks exactly what I am looking for. Where's the source for the Antes plan? ![]() |
Author: | Tom Armstrong [ Mon Nov 26, 2007 4:10 am ] |
Post subject: | |
Todd, I am just finishing two Antes model size 5's for my grandkids. What gauge strings do you suggest? thanks, Tom Armstrong |
Author: | JohnAbercrombie [ Mon Nov 26, 2007 12:41 pm ] |
Post subject: | |
Tom- What scale length did you use on the size 5's? If they're short scale you can probably put mediums on if you need to. Also, those smaller bodies have a lot less 'span' of top than a bigger guitar, so they are surprisingly stiff- unless you did the 'right thing' ![]() I built a couple of Antes with 25.4 scale last year, and nothing's blown up yet! Cheers John |
Author: | Ricardo [ Mon Nov 26, 2007 2:33 pm ] |
Post subject: | |
I was thinking of going with the PL29 plans which has a 24.5 scale and tuning would be the same as a regular guitar. The body length is 18 5/16 vs 16 1/4 for the Martin 5 (which I understand is tuned as a terz). Can anyone clarify this for me? ![]() |
Author: | Ricardo [ Mon Nov 26, 2007 6:12 pm ] |
Post subject: | |
Thanks Todd, you the man! |
Author: | JohnAbercrombie [ Mon Nov 26, 2007 7:23 pm ] |
Post subject: | |
Correction: Actually, the parlour guitars I built were from the Brown Plan AGP-010, not the Antes. I'm not sure where I got the plans, but I noticed that Intl Luthier Supply had them listed. You can get the Antes plans on eBay through the seller pilgrimsprojects - I recall getting assurances that these are legal copies, but you should confirm. Cheers John |
