It is currently Sat Jul 26, 2025 12:44 am
PostPosted: Wed Apr 06, 2005 12:42 am
Hi all, I'm getting ready to rout a hole in the side of 3 guitars for an on-board EQ pickup system...my plan is to make up a jig with a cutout the right size, to index off the top of the guitar, held by a quick clamp and rout the hole with a dremel or lam trimmer...the spot where the EQ will go has a 3/32" BB ply "patch" on the inside so I'm not too worried about splitting the side, just about whether all this will work! It's obviously an all-or-nothing propisition! Anyone out there done this kind of thing before? TIA.
PostPosted: Wed Apr 06, 2005 1:40 am
First name: Josh
Last Name: French
City: Houston
I've done this a bunch of times for people. Just freehand route a hole, and trued it up with some files or sanding sticks. Fishman and others offer templates for what the hole needs to look like. Takes very little time.
Instagram: @jfrenchluthier
PostPosted: Wed Apr 06, 2005 6:01 am
I use a keyhole saw. There's a lot less potential for causing damage if you slip with it. Just draw the shape on the side, drill a small hole to get the saw in and away you go.
Pete
PostPosted: Thu Apr 07, 2005 3:37 pm
I've used a spiral cutting bit in my Black and Decker rotary tool (Dremel type) to freehand the cut using the paper template supplied by most venders. Then I clean up with files. I've also cut it using a small X-Acto saw blade that fits their handles. I wouldn't use a regular router. It is too powerful and can get away from you in this application.
PostPosted: Fri Apr 08, 2005 4:17 am
First name: Josh
Last Name: French
City: Houston
I should have mentioned to use a dremel, not a router, to route the cavity.
