End Graft http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=2011 |
Author: | JeremiahB. [ Thu May 19, 2005 2:00 am ] |
Post subject: | |
I'm getting ready to inlay the end graft on my first guitar and I was wondering what type of glue or cement most of you use for this. It's an ivoroid end piece and has two strips of plastic purfling that go down the sides. Which works better - CA or Duco (or Weld on)? |
Author: | LanceK [ Thu May 19, 2005 2:04 am ] |
Post subject: | |
Ive only used DUCO for plastic/ivoride bindings. I've heard you can wipe the gluing edges with acetone to sofen them up and then glue with tightbond or LMI white. |
Author: | John Mayes [ Thu May 19, 2005 2:19 am ] |
Post subject: | |
for endgrafts we always used CA when at pantheon. They may do it different now, so I can't say, but I did hundreds with CA and it worked like a charm. |
Author: | Michael Dale Payne [ Thu May 19, 2005 2:31 am ] |
Post subject: | |
I have done the acetone and titebond but use CA now when doing plastic. |
Author: | JeremiahB. [ Thu May 19, 2005 2:47 am ] |
Post subject: | |
When using CA, do you apply directly to the end graft and then flood along the purfling lines? |
Author: | Dave Rector [ Thu May 19, 2005 3:03 am ] |
Post subject: | |
I use a combination made up od wood with plastic purfling strips that I get from Martin. I get everything fit up real well then flood it with CA. Haven't seen a problem with it yet. |
Author: | Michael Dale Payne [ Thu May 19, 2005 3:55 am ] |
Post subject: | |
I apply medium viscosity CA to the bottom of the channel. fit the graft and wick edges with thin viscosity CA |
Author: | John Mayes [ Thu May 19, 2005 6:59 am ] |
Post subject: | |
[QUOTE=JeremiahB.] When using CA, do you apply directly to the end graft and then flood along the purfling lines?[/QUOTE] I just used thick CA for the whole kit and caboodle. |
