It is currently Sun Jul 27, 2025 4:40 am
PostPosted: Thu Jun 09, 2005 9:43 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Do you have to fill Macassar Eboney?
PostPosted: Fri Jun 10, 2005 1:04 am
I have not built a guitar with macassar yet, but I can tell you from some turning work that I have lacquered that I have finished two pieces side by side, one epoxy "filled" and the other not.
The epoxy filled piece looked much "wetter" and glossier than the un filled piece. The finish had a much deeper look.
Neither showed the small pores though.
PostPosted: Fri Jun 10, 2005 5:07 am
I use macassar quite a bit for headstock veneers. I have always filled them using epoxy. I tried it without filling and had quite a few pores showing. It is not a very big piece to deal with so a couple of drops of epoxy usually does it.
Never done a back and side set though.
PostPosted: Fri Jun 10, 2005 5:16 am
First name: Roger
Last Name: Labbe
If a wood has pores, you have to fill them one way or another if you don't want them showing. Macassar has pores, albeit small ones.
PostPosted: Fri Jun 10, 2005 6:21 am
Last Name: Johnson
State: CO.
THANKS EVERYBODY
Users browsing this forum: Bing [Bot] and 3 guests
