It is currently Sun Jul 27, 2025 9:56 am
PostPosted: Tue Jul 05, 2005 11:26 am
I've gone insane, and I'm building a wide belt sander. All those years in mechanical engineering school should be good for something, certainly didn't help my spelling. Hey, if Jim Olson can do it...
First question, what size sanding belts does your sander take?
Where do you get belts?
Anyone that has a rubber conveyor belt, does it have metal lacing at the splice, or is it an endless belt?
Does anyone have a sander that doesn't use air?
PostPosted: Thu Jul 07, 2005 2:24 am
First name: Nelson
Last Name: Palen
Eric
Have you considered using a sanding belt for the conveyor? Seems to work well and fairly inexpensive.
Nelson
PostPosted: Thu Jul 07, 2005 2:50 am
You may be able to get a replacement conveyor belt from one of the other manufactuters. My ryobi has a rubber conveyor although it is not real long nor very wide. It is a continuos belt though. I think the newer performax units have this same type of belt, also some of the Grizzly wide belt sanders may have belts such as you will need. It will be interesting to watch your progress so please kkeep us posted.
PostPosted: Thu Jul 07, 2005 7:45 am
[QUOTE=npalen] Eric
Nelson
I was going to do that, but I can order the drive belt from McMaster, I'm trying to figure out what kind of belt I should get. This leads back to my original post. If I had to boil my original questions down to one, it would be: can I get any length and width of sanding belt I want?
I've had the drums for a number of years now, but I finally figured out how the tracking mechanism should work. That was definitely holding me back. I have about 90% of the parts on hand. I was going to post a picture of all the parts lying in a pile like some people do before they start working on a guitar.
It's going to be 24" wide. I thought about just buying a drive belt from Grizzley. Don't know if they will sell me one though.
Thanks for the encouragement.
PostPosted: Thu Jul 07, 2005 7:50 am
I'm sure they would. Go to their website and dowload the PDF file for the manual/parts guide.John How38540.7025925926
PostPosted: Thu Jul 07, 2005 10:54 pm
   I use INDUSTRIAL ABRASIVES
   1-800-428-2222
   I use a 48 by 60 belt in my machine..Actually my friends as he has a timesaver unit in his cabinet shop. Does a bang up job. Ask for the non loading paper. A little more expensive but last alot longer than the standard stuff
john hall
