Compensation Question http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=2707 |
Author: | csullivan [ Thu Aug 04, 2005 5:27 am ] |
Post subject: | |
Hi to everyone. Although I’m not new to guitar building, I am new to your discussion group as a member. I’ve been lurking in the shadows listening to what you all have to say for quite awhile now (great wisdom abounds, I must say). Those of you who are members of the New England Luthiers group know me (though some might not admit to it). So now I have a question. I’m building a jumbo guitar with a 25.5” string length. I’ll be cutting the fret slots using an LMI template. Since they’re machined so that any slot can be used as a zero fret, they use a double- ended indexing pin, one end of which compensates for the blade width so you can cut a zero fret. However, I have read comments from some of you that suggest you shorten the distance from the nut to the first fret by as much as 1/32”. If then, I make a new indexing pin I can accomplish the same degree of compensation. Is 1/32” the magic number (sounds like a lot), or is there some sort of formula someone has derived based on string length? And question 2. In the past I have used saddle compensation dimensions for my dreadnoughts passed on to me 20 years ago by someone long forgotten. Since this jumbo has a longer string length than my dreadnoughts, does anyone out there have a formula/guideline for determining the amount of compensation required from bass to treble? Obviously, I’d like to avoid cobbling together some sort of temporary adjustable bridge and then taking measurements. I keep hearing “Oh, about 1/8” sounds good,” but I’d feel more comfortable with something with more substance behind it. Of course, action height has a bearing on this, but let’s assume this is a well-tuned guitar with a reasonably low action. I can’t wait to hear the flow of wisdom pour forth!JavaScript: AddSmileyIcon(' ![]() |
Author: | crazymanmichael [ Thu Aug 04, 2005 6:38 am ] |
Post subject: | |
seems this question got entered twice! |
