Ebony and Spruce. http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=2718 |
Author: | RussellR [ Thu Aug 04, 2005 6:47 pm ] |
Post subject: | |
I did a couple of rosettes which contained ebony recently and have another onr to do, I had a hell of a time eith the dust from the ebony rosette and bindings getting into the top, I was wondering if there is a simple method for preventing this or cleaning the top after, I wondered if it would be worth giving the top a thin seal coat of shellac before I start ? |
Author: | Bobc [ Thu Aug 04, 2005 10:08 pm ] |
Post subject: | |
Russell thats what I do. It helps a lot. Of course I havn't installed a rosette in so long I think thats what I do. ![]() |
Author: | RussellR [ Thu Aug 04, 2005 10:11 pm ] |
Post subject: | |
Bob thank you |
Author: | Don Williams [ Thu Aug 04, 2005 10:12 pm ] |
Post subject: | |
[QUOTE=Bobc] Russell thats what I do. It helps a lot. Of course I havn't installed a rosette in so long I think thats what I do. ![]() Bob, you need to get building again! All that knowledge is starting to seep out. Patch those neural holes and get buildin'! |
Author: | Bobc [ Fri Aug 05, 2005 2:02 am ] |
Post subject: | |
[/QUOTE] Bob, you need to get building again! All that knowledge is starting to seep out. Patch those neural holes and get buildin'![/QUOTE] Actually I was thinking of taking a ride up to your place for a refresher course. ![]() |
Author: | Michael Dale Payne [ Fri Aug 05, 2005 3:30 am ] |
Post subject: | |
The shellac is the trick, a little shellac also helps the prevent small dings. doesnt eliminate the possibility but helps |
Author: | crazymanmichael [ Fri Aug 05, 2005 3:52 am ] |
Post subject: | |
i am assuming that you are refering to the dust from leveling the rosette with the top; easy solution is to use a scraper; voila, no dust only shavings. |
Author: | RussellR [ Sun Aug 07, 2005 9:19 am ] |
Post subject: | |
Hi Michael I would normally, but in this instance The ebony has mop inlayed. |
