Why Hammer Frets After Neck Is On Body http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=3411 |
Author: | GregG [ Mon Oct 03, 2005 4:38 am ] |
Post subject: | |
Hi All, Can you please explain to me the reasoning behind installing frets 14 & higher after the fretboad/neck are affixed? |
Author: | LanceK [ Mon Oct 03, 2005 4:43 am ] |
Post subject: | |
for me its very simple - I'm able to level my fretboard (After) its attached to the body - I have NEVER had luck trying to get the neck to line up perfectly with the top of the body, so there is always a little bit of leveling to do. That and the fact that it is SO SO easy to fret after word, I see no point in doing it ahead of time - Just my way - or the way I do it ![]() |
Author: | Brock Poling [ Mon Oct 03, 2005 4:45 am ] |
Post subject: | |
sure... so you can true up the fingerboard and make sure it is dead flat all the way up the board after it is attached. |
Author: | Sprockett [ Mon Oct 03, 2005 5:00 am ] |
Post subject: | |
This Gentlemen is WHY I have a %100 detachable neck, I do all this with the neck removed and then just bolt it on when I'm ready ![]() ![]() ![]() I'm trying to convince Woolson that he should convert over, it would save him some of the problems with his roadtrip guitar.... -Paul- |
Author: | Tim McKnight [ Mon Oct 03, 2005 5:40 am ] |
Post subject: | |
http://luthiersforum.3element.com/pages/jig_tools_tech/frett ing_by_tim_mcknight.htm The article ^above^ explains it. |
Author: | Don Williams [ Mon Oct 03, 2005 5:47 am ] |
Post subject: | |
Nice article Tim, eh? ![]() |
Author: | Tim McKnight [ Mon Oct 03, 2005 11:53 am ] |
Post subject: | |
[QUOTE=Don Williams] How pretty is that article?[/QUOTE] Pretty is as pretty does.... Did I mention that my fingers type faster than my brain thinks .... and who has time to proof read? Thanks Don. |
Author: | LanceK [ Mon Oct 03, 2005 12:08 pm ] |
Post subject: | |
Tim, Its nice to see someone other than me getting GRIEF from Don over sppeling!! ![]() |
Author: | Michael Dale Payne [ Tue Oct 04, 2005 1:26 am ] |
Post subject: | |
you guys that can get the fretboard dead on then bolt it up make me invious. I always find I need a tweek to get it right. My first I freted through the 14 prior to setting the neck. When I fret leveled I had too much trouble. From then on I set the neck, finished the guitar and neck, installed the bridge, mounted the neck, leveled the fretboard then installed the frets. I have had a lot less issues to deal with since I started doing it this way. and a lot less fret recrowning. |
Author: | Tim McKnight [ Tue Oct 04, 2005 11:54 am ] |
Post subject: | |
I haven't re-crowned a fret in 35+ guitars since using this method. Once the FB is dead flat the only variation left is in the fret itself (and of course the guy swinging the hammer). |
Author: | arvey [ Tue Oct 04, 2005 2:11 pm ] |
Post subject: | |
I fret the finger board before attaching it to the neck and have only once had to level the frets after. That was on a guitar that had been out for two months and exposed to some real extreams in Humidity and even then it didn't ned much. |
Author: | Colby Horton [ Wed Oct 05, 2005 12:05 am ] |
Post subject: | |
Tim, thats pretty amazing. How low are you able to get your action without buzzing? 3/32" or 1/8" over the twelfth fret? |
Author: | crazymanmichael [ Wed Oct 05, 2005 3:08 am ] |
Post subject: | |
if you can't get your action lower than 3/32" or 1/8" without buzzing you haven't finished fretting yet. |
Author: | arvey [ Wed Oct 05, 2005 3:12 am ] |
Post subject: | |
I have never been able to figure out why people have to re crown so often. Do a good job fretting and you shouldn't need to touch them. |
Author: | Tim McKnight [ Wed Oct 05, 2005 6:51 am ] |
Post subject: | |
[QUOTE=arvey] I have never been able to figure out why people have to re crown so often. Do a good job fretting and you shouldn't need to touch them.[/QUOTE] Amen, brotha' |
Author: | Don Williams [ Wed Oct 05, 2005 7:00 am ] |
Post subject: | |
[QUOTE=LanceK] Tim, Its nice to see someone other than me getting GRIEF from Don over sppeling!! ![]() [/QUOTE] That's "spelling" not "sppeling" or "Sapeleing" ![]() |
Author: | John How [ Wed Oct 05, 2005 7:24 am ] |
Post subject: | |
Don haven't you heard about the new tone wood "curly sppeling". Rare stuff indeed. |
Author: | Don Williams [ Sat Oct 15, 2005 2:25 am ] |
Post subject: | |
![]() ![]() Good one John! |
