It is currently Wed Jul 30, 2025 12:36 am
PostPosted: Mon Oct 17, 2005 3:51 am
I usually spray about three coats of nitro a day. Is it necessary to flush the gun with lacquer thinner after each coat or just at the end of the day?
PostPosted: Mon Oct 17, 2005 4:39 am
City: Tyler
End of day works for me.
PostPosted: Mon Oct 17, 2005 4:41 am
I keep a canister loaded with thinner and spray for 10 sec after each coat. I have not always done this but on warm days it can save time clearing the needle. if under 80 deg, once a day would probably work.
PostPosted: Mon Oct 17, 2005 7:03 am
First name: Nelson
Last Name: Palen
You guys will probably ostracize me but I never flush my lacquer gun. Never had a problem with it.
Nelson
PostPosted: Mon Oct 17, 2005 7:06 am
First name: Nelson
Last Name: Palen
Forgot to mention that I never empty the cup either.
Sits for several weeks some times between spraying. Just pick it up and start spraying.
Now I'm really in trouble.
Nelson
Your right Nelson......go put your head in the sand..OH you said ostracize... I thought you ment ostridge-cize Just kidding MichaelP38642.6765972222
PostPosted: Mon Oct 17, 2005 7:59 am
State: ON
I know a guy who goes for months without cleaning the cup on his gun. He has very few problems with it not working. I would not recomend this, but you can get away with leaving the lac in the gun for some time.
It is probably better to get into a good habit of cleaning your gun.
josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Oct 17, 2005 8:40 am
First name: Nelson
Last Name: Palen
I do clean my dye gun religiously immediately after each use. Flush it and store it with a little MEK in the cup. Eliminates occasional spatter of a piece of concentrated dye when spraying. (gravity fed HVLP)
Figured I better mention this less you guys think I'm some kind of a redneck.
Nelson
PostPosted: Mon Oct 17, 2005 9:23 am
Dang! I just always leave a cup fulla lac in my gun as well, and never have a problem with it...'course, my shop is a hundred degrees all summer long too, so it never has a chance to set in the nozzle!
PostPosted: Mon Oct 17, 2005 10:16 am
I have a jar of thinner and spray thru after each coat. It only takes a second .
PostPosted: Mon Oct 17, 2005 12:01 pm
I also leave nitro in my gun for my spray sessions. One day I thought how come I don't have to worry about spray cans not working after a few days and how different is my spray gun really? Any way for me leaving lacquer in there for a week or so works fine. The gun gets a good cleaning after however.
PostPosted: Mon Oct 17, 2005 3:02 pm
I am a redneck, but I spray 3 coats of laq 35 to 45 min apart and clean up my equipment after I am finished. Never saw any need to clean between coats.
D.L.
