Question about spraying nitro. http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=3547 |
Author: | Colby Horton [ Mon Oct 17, 2005 3:51 am ] |
Post subject: | |
I usually spray about three coats of nitro a day. Is it necessary to flush the gun with lacquer thinner after each coat or just at the end of the day? |
Author: | Glen H [ Mon Oct 17, 2005 4:39 am ] |
Post subject: | |
End of day works for me. |
Author: | Michael Dale Payne [ Mon Oct 17, 2005 4:41 am ] |
Post subject: | |
I keep a canister loaded with thinner and spray for 10 sec after each coat. I have not always done this but on warm days it can save time clearing the needle. if under 80 deg, once a day would probably work. |
Author: | npalen [ Mon Oct 17, 2005 7:03 am ] |
Post subject: | |
You guys will probably ostracize me but I never flush my lacquer gun. Never had a problem with it. Nelson |
Author: | npalen [ Mon Oct 17, 2005 7:06 am ] |
Post subject: | |
Forgot to mention that I never empty the cup either. Sits for several weeks some times between spraying. Just pick it up and start spraying. Now I'm really in trouble. ![]() Nelson |
Author: | Michael Dale Payne [ Mon Oct 17, 2005 7:06 am ] |
Post subject: | |
Your right Nelson......go put your head in the sand..OH you said ostracize... I thought you ment ostridge-cize Just kidding ![]() ![]() |
Author: | Josh H [ Mon Oct 17, 2005 7:59 am ] |
Post subject: | |
I know a guy who goes for months without cleaning the cup on his gun. He has very few problems with it not working. I would not recomend this, but you can get away with leaving the lac in the gun for some time. It is probably better to get into a good habit of cleaning your gun. josh |
Author: | npalen [ Mon Oct 17, 2005 8:40 am ] |
Post subject: | |
I do clean my dye gun religiously immediately after each use. Flush it and store it with a little MEK in the cup. Eliminates occasional spatter of a piece of concentrated dye when spraying. (gravity fed HVLP) Figured I better mention this less you guys think I'm some kind of a redneck. Nelson |
Author: | L. Presnall [ Mon Oct 17, 2005 9:23 am ] |
Post subject: | |
Dang! I just always leave a cup fulla lac in my gun as well, and never have a problem with it...'course, my shop is a hundred degrees all summer long too, so it never has a chance to set in the nozzle! ![]() |
Author: | Dave Anderson [ Mon Oct 17, 2005 10:16 am ] |
Post subject: | |
I have a jar of thinner and spray thru after each coat. It only takes a second . |
Author: | Jim Watts [ Mon Oct 17, 2005 12:01 pm ] |
Post subject: | |
I also leave nitro in my gun for my spray sessions. One day I thought how come I don't have to worry about spray cans not working after a few days and how different is my spray gun really? Any way for me leaving lacquer in there for a week or so works fine. The gun gets a good cleaning after however. |
Author: | D.L.Huskey [ Mon Oct 17, 2005 3:02 pm ] |
Post subject: | |
I am a redneck, but I spray 3 coats of laq 35 to 45 min apart and clean up my equipment after I am finished. Never saw any need to clean between coats. D.L. |
