It is currently Wed Jul 30, 2025 5:58 pm
PostPosted: Mon Oct 24, 2005 5:16 am
Sorry for the off topic post. I fugure someone here might know something about this.
I bought a used Phillips DVD player/receiver. The speaker wire has been cut and the propriotary plugs are missing. I need to either find the plugs or 1/16" "spade" plugs. I'm not sure that's what they are called which might be why I can't find them. Any tips?
PostPosted: Mon Oct 24, 2005 5:18 am
Radio Shack
PostPosted: Mon Oct 24, 2005 5:24 am
no luck there. too small
PostPosted: Mon Oct 24, 2005 5:58 am
They are not RCA jacks?...HMMMM
PostPosted: Mon Oct 24, 2005 6:11 am
Nope, they are wierd. Here's a diagram of the end view of the plug. The two spades are 1/16" wide.
PostPosted: Mon Oct 24, 2005 6:42 am
I would modify the case and replace the jacks with something less propretary, like RCA or even phono jacks. There's only two wires to worry about, so it shouldn't be too hard.
PostPosted: Mon Oct 24, 2005 6:45 am
I have dealt with those little things before, and they are easy to obtain at electronic stores, but finding a good electronic store can be hard. You can easily wire in replacement plugs as Joe mentioned. I would opt for banana plugs. They're really easy and work great. Simple silly.
PostPosted: Mon Oct 24, 2005 6:46 am
KIND OF LIKE A MINI ac PLUG...STRANGE
PostPosted: Tue Oct 25, 2005 3:22 am
Try Autozone. They carry some different sizes of spade type plugs.
