It is currently Wed Jul 30, 2025 5:55 pm
PostPosted: Fri Nov 04, 2005 2:06 am
I'm not there yet, but had a thought I wanted clarified. After all finish is applied and you are waiting 2 weeks or so to buff out, do you leave it strung up under tension or back off?
PostPosted: Fri Nov 04, 2005 2:11 am
Ron, it's easier to buff out before you actually glue on the bridge and fretboard extension...it will save you a lot of hassle.
PostPosted: Fri Nov 04, 2005 4:14 am
Thanks, Don
I knew that. I shouldn't even try to think before noon. My brain was in neutral.
Ron old man38660.5108796296
PostPosted: Fri Nov 04, 2005 7:16 am
i finish and buff out in two pieces, i.e., neck and body. it is just so much easier to buff out that way. because i am a troglodyte still using a dovetail type m&t, no strings have even approached it yet.crazymanmichael38660.6379398148
PostPosted: Fri Nov 04, 2005 7:21 am
I do as Don and Michael do. I even do as they say.
But you know, one could glue on the bridge, etc, string it up, and if it was a dog, you could forget the finishing process, and save that valuable time for a better attempt.
Brain in neutral even after noon.
PostPosted: Fri Nov 04, 2005 7:25 am
While waiting for the finish to cure, I do a sanding around the bridge area with 600/1600/2400/4000/8000 micromesh which ends up looking buffed. The I go ahead an bolt my bridge using Stew Mac bridge bolts. Bolt my neck and work on nut, saddle, fretting, action etc. Then when I am all done, I take er all apart and do the final buffing and reassembly.
