Jointer Question. What Brand is good? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=3909 |
Author: | BlueSpirit [ Sun Nov 27, 2005 2:09 pm ] |
Post subject: | |
I saving up for a jointer and I would like feedback on brands you use. I'm working with a lot of rough lumber that I need to surface before I can cut it up on the bandsaw. I could just cut the joints on the table or band saw, but I would like to keep the waste to a minimum. Any help would be appreciated. Thanks! |
Author: | Shane Neifer [ Sun Nov 27, 2005 2:16 pm ] |
Post subject: | |
Doug, I have an 8 inch General (Canadian Made) but they are expensive (In excess of $2000). I would like a 12 inch to flatten out faces before I resaw but they are too much money for now so I use a sliding table to square my blocks. There are 8 inch imports and I have read that the grizzly s pretty good. I did have a 6 inch import for about 15 years that served me well for fine woodworking stuff I was doing. Hope this is of some help! Shane |
Author: | Chas Freeborn [ Sun Nov 27, 2005 2:56 pm ] |
Post subject: | |
You're not saying how much you can spend, so this may be out of the question, but the 12" spiral cutter head Grizzly is quite a machine. By the time you get it delivered it'll run you about $4K. Once you go spiral, you'll never go back. -C |
Author: | Tim McKnight [ Sun Nov 27, 2005 3:12 pm ] |
Post subject: | |
I've had a 6" Jet for nearly 20 years and have not done a thing to it other than sharpen the blades. I have often wished for an 8" ONLY for the longer bed BUT the 6" has done all I have ever asked of it. |
Author: | Howard Klepper [ Sun Nov 27, 2005 8:17 pm ] |
Post subject: | |
I have been happy with my Delta DJ-20 for the past four years or so. The fence has to be squared to the tables when it is moved, but no other complaints. It has a unique table adjustment mechanism that combines the sensitivity of handwheels with the speed of lever rods. Tables have stayed flat and parallel. I think there is a 6 inch version called DJ-15. A trustworthy jointer is a fine thing to have in the shop. |
Author: | Jason [ Sun Nov 27, 2005 8:37 pm ] |
Post subject: | |
Doug save for the grizzly spiral 12" and just go pick it up from the showroom in bellingham. We did and it's great. We use it for the same thing you will |
Author: | BlueSpirit [ Sun Nov 27, 2005 9:11 pm ] |
Post subject: | |
Thanks everyone. I really appreciate all the imput. Jason, That Griz sounds good. Arn't those spiral cutters the little squares you can rotate 4 times and then even sharpen them? And I forgot I could pick it up. I need to look into that one. Thanks! |
Author: | old man [ Mon Nov 28, 2005 2:07 am ] |
Post subject: | |
I have a 6" Jet, also and am very pleased with it. Ron |
Author: | Jason [ Mon Nov 28, 2005 4:47 pm ] |
Post subject: | |
Ya the spirals have the little blades you can rotate 4 times.. you could probably sharpen them but I wouldnt recommend it unless you had a jig that sharpened every blade to the exact same size/shape.. you could be opening yourself up for a real headache. I've run.. at least 600 billets of flamed maple through ours so far.. probably closer to 7 or 800.. We haven't even had to turn the blades yet. I have one tiny chip in a blade but it's not big enough to justify turning them. I think another major selling point for these things is how quiet they are. It makes less noise than the dual bag dust collector hooked to it. |
Author: | EricKeller [ Mon Nov 28, 2005 5:07 pm ] |
Post subject: | |
Fine woodworking just had a review of the new Grizzley 8" that was positively glowing. The spiral head machine sounds great. I recently upgraded from a 6" Jet to a 8" Delta. It would be nice to be able to surface guitar sized wood. |
Author: | Robbie O'Brien [ Wed Nov 30, 2005 1:41 am ] |
Post subject: | |
We just got the new Grizzly spiral at the school and it is SWEEEEEEEEEEEEEEEEEEET!!!! I think the 8inch grizzly like the one written about in the latest issue of Fine Woodworking is a great deal but I would definitely upgrade it to the spiral head. |
