How long does it take for a bridge to dry http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=4312 |
Author: | John Kinnaird [ Sun Jan 01, 2006 12:18 pm ] |
Post subject: | |
I glued a bridge on a few days ago, LMI glue, and then when drilling holes for the pins through the top, noticed that the glue under the bridge in the center, was less than crystal hard. The bridge had been clamped in place for a couple of days. I wonder how long glue that is not exposed to air, trapped between the saddle and the top, remains unhard. |
Author: | JJ Donohue [ Sun Jan 01, 2006 12:56 pm ] |
Post subject: | |
I can't speak for the LMI stuff but I just did another 5 piece neck laminate (4"x4") using Titebond and had it bandsawn into 2 necks after 24 hours. There was no indication that the glue was still soft anywhere along the cut lines. |
Author: | Bob Steidl [ Sun Jan 01, 2006 1:26 pm ] |
Post subject: | |
John, if you were drilling through holes that you had made in your bridge before you glued it to the top (as most of us do), then I would not be too surprised if the 3/16" thick wad of glue in the hole was not cured. Once a big pile of glue gets a skin on it, it takes quite a while to cure. Smear a thin bit of that glue on a piece of scrap. If it dries normally, then I bet you're okay. |
Author: | Colin S [ Sun Jan 01, 2006 9:06 pm ] |
Post subject: | |
You weren't heating it up with that drill were you? Colin |
Author: | John Kinnaird [ Mon Jan 02, 2006 1:40 am ] |
Post subject: | |
Yes, I was redrilling the holes through the bridge and into the top so skinning certainly happened. And, Colin, perhaps the heat of the drill did soften the glue to some extent. Nevertheless I am left wondering if part of the dramatic improvement of the tone of a new is not in part due to the complete hardening of the adhesives. Just a thought. |
Author: | Colin S [ Mon Jan 02, 2006 1:48 am ] |
Post subject: | |
My civil engineer son tells me that concrete takes more than a hundred years to reach full hardness, I am surprised that the crystalisation process in concrete is that fast (the crystal structure of some rocks can still be changing after millions of years). I would think that the crystal structure of glues would not have stabilised for many years particularly if subject to environmental changes. So, not only do we have to wait 50 years to hear the potential of the wood in our guitars but also for the glue to stabilise. John this is really quite depressing. Colin |
Author: | Frank Ford [ Mon Jan 02, 2006 4:06 am ] |
Post subject: | |
Colin - For what it's worth, hide glue does not undergo any chemical change as it hardens. It hardens by evaporation of the solvent (water) and can be reactivated to its original state at any time with the same solvent. Concrete isn't even remotely similar. It can harden under water, for example. So, fear not, hide glue gets as solid as it ever will in a very short while. Oh, yes, and the residual wet glue in the bridge holes is not a problem if the joint has been clamped and dried overnight. |
Author: | Colin S [ Mon Jan 02, 2006 4:18 am ] |
Post subject: | |
Frank, if you read John's original question you'll see that he refers to LMI glue, neither he nor I mentioned hide glue. I refer to crystalisation processes, even the evaporation of water in hide glue causes a crystalisation process to take place albeit a reversible one. However, if hide glue is 'dissolved' in water then yes, as it hardens it must indeed undergo a chemical change, only if it is just in suspension will there be only evaporation with no change to the chemical structure. Colin |
Author: | CarltonM [ Mon Jan 02, 2006 8:06 am ] |
Post subject: | |
What was your shop temp.? Colder equals a longer cure time. Warmer (definately need over 65 deg. F.) equals a faster cure time. Really, with PVA glue, over 70 F. is best for a 24 hour cure, from what I've read and heard. |
Author: | Frank Ford [ Tue Jan 03, 2006 4:12 pm ] |
Post subject: | |
I guess I was scanning that post a bit too quickly. I somehow managed to come up with hide glue, maybe because of the "crystal hard" part. In any case, I don't think there's much to worry about. A properly constructed glue joint has precious little glue actually in it, and there's close to a solid mechanical bond between the two pieces, I think. At any rate, I've reglued quite a few bridges on instruments where the bond was many decades old and solid, without hearing a bit of degradation in tone. In all cases, I allow overnight drying as a minimum for any clamped glue joint - it's not all that long to wait. |
Author: | L. Presnall [ Wed Jan 04, 2006 2:56 am ] |
Post subject: | |
So, is it dry yet? ![]() |
Author: | John Kinnaird [ Wed Jan 04, 2006 3:27 am ] |
Post subject: | |
I suppose its dry. It is certainly dry around the edges but it was the hidden encapsulated parts that I was curious about. |
