It is currently Sun Aug 03, 2025 10:17 am
PostPosted: Thu Jan 12, 2006 7:20 am
Okay all you engineer types out there...I'm appealing to your wisdom...I want just a touch more neck relief in an OM I built a while back...the one where the truss rod nut was broken off ...that ordeal's over, and I pulled all the frets, leveled the f/b and refretted...all nice and smooth, but the new truss rod configuration is somewhat limited in that it's a one-way rod now...I'd like to see just a touch more relief, so I can keep the action where it is....all that to ask, could I get away with med or lt top/heavy bottom strings on an OM? The bracing's all "standard"...TIA.
PostPosted: Thu Jan 12, 2006 8:12 am
Only you would know how you braced it but there should be no reason you couldn't use mediums on an OM.
PostPosted: Thu Jan 12, 2006 8:24 am
Hesh, those are the VERY strings I bought to put on there depending on the advice I got here...
John, yep it's run-of-the-mill bracing for an OM right to the Martin plan...LMI white tho.. (I was never nervous about that til I read all the stuff on the forum!)...what the hay, I'll do it and keep a close eye on it for a week...
Thanks guys!
PostPosted: Thu Jan 12, 2006 8:33 am
I've use that glue on the last 15 or so builds without so much as a hint of trouble.
PostPosted: Thu Jan 12, 2006 9:02 am
State: ON
I think you should be fine.
GHS makes a True medium gauge which is a bit heavier than lights. Or the D'add bluegrass set that was already mentioned. I would try those first and see if that helps.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Jan 12, 2006 10:48 am
Larry,
I wonder if, after some period of time under the extra pull of the mediums, the neck would take enough of a set that you could go back to your usual strings. Possibility?
