It is currently Mon Aug 04, 2025 5:28 am
PostPosted: Sat Jan 28, 2006 4:34 pm
I am making myself a small parlor like guitar for travel. The body mold I
have is an 0 martin 12 fret. The only plans I have are for a "small concert
parlor " guitar by Scott Antes. The 0 martin is a bit bigger. (Wider and
longer body) My plans call for only one tone bar and one finger brace on
each side of the X braces. Since my guitar is a bit bigger would you change
the bracing pattern?
2 tone bars???
more finger braces???
I have never made any guitar smaller than an OM so I have no clue.
Suggestions....help????
Andy
PostPosted: Sat Jan 28, 2006 4:59 pm
I snagged a bracing scheme from the MIMF and took it to a copy shop and had it blown up full to size. I don't know how faithful it is to the original, but it makes a nice guitar.
PostPosted: Sat Jan 28, 2006 5:06 pm
I'd stay with the Antes bracing, but check out Brock's suggestion to get alternative ideas.
PostPosted: Sat Jan 28, 2006 5:13 pm
Andy, here is a Gibson L-00 bracing, about the size of what you are talking about. Take a look, 2 tone bars, 1 finger brace, 1/4 inch brace stock.
PostPosted: Sat Jan 28, 2006 9:12 pm
On the basis that most guitars are way overbraced (my present hobby horse) I'd stick with the single tone bar, or put a single transverse bar ala larivee.
PostPosted: Sun Jan 29, 2006 12:34 am
Hi Andy
On my O Size I use a double Tone Bar and Double Finger Braces. I sort through for tops which are more flexible than I would usuallt use.
My Bracing is like this
PostPosted: Sun Jan 29, 2006 1:18 am
If you want Martin Bracing I have the actuall tracings from the production floor. Antes layout is close. You do have to remember that bracing is scale length oriented.
   The 0 has 1 tone bar and 1 finger brace. The X braces also don't go as high up the body towards the neck.
If you need to I am in the shop 570-682-8046 and I can help you out over the phone
john
PostPosted: Sun Jan 29, 2006 1:41 am
Andy
