It is currently Mon Aug 04, 2025 1:51 pm
PostPosted: Mon Feb 20, 2006 6:14 am
Does anyone have a good source for tutorials on laying Abalone or Pearl Rosettes?
-jack handy
PostPosted: Mon Feb 20, 2006 6:19 am
Check out Taylor Factory Fridays....they have a pretty nice video on inlaying a Rosette!
PostPosted: Mon Feb 20, 2006 7:49 am
I've got the actual inlay part down with typical rosettes, I've just never worked with abalone before and wanted to see how to get the edges lined up, how to fill gaps, etc. with abalone and shell in general.
Thanks.
-j.
-jack handy
PostPosted: Mon Feb 20, 2006 10:31 am
Not sure if this will be helpful to you -- Brock Poling has a tutorial on making an abalone rosette here on the OLF. Also I thought the C&N book has a pretty good illustrated description.
Hope that helps. Anthony Z38768.7734027778
PostPosted: Tue Feb 21, 2006 10:16 am
I'll search for it. Thanks.
-jack handy
PostPosted: Tue Feb 21, 2006 12:38 pm
Here is the link if anyone is interested. I am not using that method to join my tops anymore. I have moved to a hand plane and a shooting board - it is a lot less effort than screwing around with the jigs.
THIS LINK
PostPosted: Tue Feb 21, 2006 2:27 pm
I never did pay much attention to your prior top joining method
But -- I thought your method of making and laying up rosette's with a UHMW jig was pretty clever.
PostPosted: Tue Feb 21, 2006 3:18 pm
Thank you very much Brock, very timely too as i'm about to make my rosettes, love the UHMW plate idea also!
At one of the local hardware stores, they sell bottles of liquid shellac, anyone knows if this stuff is good or bad to protect the wood from CA glues for rosettes ?
TIA, sorry if i'm hijacking.
PostPosted: Tue Feb 21, 2006 3:21 pm
Yes, that should be ok. Just make sure it dries well before you use it. I also use the spray shellac sometimes if I don't have any fresh mixed up.
PostPosted: Tue Feb 21, 2006 3:25 pm
Cool Brock thanks, i thought of asking you folks before doing anything foolish. now, i just hope they sell router bits of 1/16" and 1/32", would 3/32" be too big for this application ?
PostPosted: Tue Feb 21, 2006 4:01 pm
I have three UHMW plates with pre routed to accept .063 4.93id abalone rosete and .04 bwb purfling each side and .095 4.93is abalone rosete .06 bwb and one for 1/8" abalone rosete with .06 bwb. really makes glue up easy.
J. as far as fitting joints if it is a solid ring abalone seams darn near diaperar if you stage your color trasitions well, not so with MOP. There is no good filler th fill a seam gap. Tight edges with abalone will make near invisible seams, But you will always have visible seams with MOP
Most of us buy pre radiused abalone or MOP rosetes. They come in the witdths I list above. They all have 4.93 ID. The OD varries based on width of shell. They come in usally 4 to 8 pieces to make a 360 ring. MichaelP38770.0021064815
PostPosted: Thu Feb 23, 2006 10:44 am
Thanks for the info, all. Brock, that is a seriously robust document. Nice work.
-j.
-jack handy
Users browsing this forum: No registered users and 43 guests
