Kinky Sanding Pads http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=5523 |
Author: | npalen [ Wed Mar 08, 2006 6:28 am ] |
Post subject: | |
I discovered last evening that a 1/2 oz. size TicTac box works pretty good. It's about the right size for a quarter sheet of sandpaper that has been quartered again. (2 1/4" x 2 3/4") The plastic box has some flexibility but not too much. Fill it with your favorite wet sanding solution for a "ready reservoir". Throw in a few BB's for some sound effects and you can sand in time with your favorite music. I'll bet you guys have come up with some strange devices to use as sanding pads also? Nelson |
Author: | Bruce Dickey [ Wed Mar 08, 2006 6:57 am ] |
Post subject: | |
New flip flops run through the bandsaw. Soft, flexible, cheap. I think that idea came from Frank of Frets.com? |
Author: | Dave Rector [ Wed Mar 08, 2006 7:29 am ] |
Post subject: | |
My large rubber erasers from the Office Depot are one of my favorite sanding blocks. They'll even sand around the curves after the sides have been glued up. |
Author: | Brock Poling [ Wed Mar 08, 2006 7:35 am ] |
Post subject: | |
While I was trying to stuff my fingers down inside the ramps of a slot head to sand them (without changing the shape) I was thinking it would be a great idea to make erasers with sanding grits embedded into them. They could be shaped to fit into those spots but still be abrasive. |
Author: | Michael Dale Payne [ Wed Mar 08, 2006 7:37 am ] |
Post subject: | |
rough sanding I use the back of my neck when Diane is yelling at me perfect 80 grit ![]() ![]() |
Author: | burbank [ Thu Mar 09, 2006 5:06 am ] |
Post subject: | |
empty toilet paper rolls for the waist and inner curves on neck heel and headstock |
Author: | Joe Beaver [ Thu Mar 09, 2006 5:28 am ] |
Post subject: | |
What's next? Tampons to polish the sound hole? Will it never end? |
Author: | Jimson [ Thu Mar 09, 2006 6:50 am ] |
Post subject: | |
We have wide roll plotters at work. The paper is wound on plastic tubular cores that are great for sanding 'blocks'. I use rubber cement to retain the sandpapers. You can get several pads from one tube. Another office item I have used is empty dry erase marker tubes from the conference room wastebaskets. |
Author: | Michael Dale Payne [ Thu Mar 09, 2006 7:27 am ] |
Post subject: | |
I dont want to scare you but depending on what you use this round form to sand, You might want to put a straight edge to the tube be for using. Being in a engineering department myself, we also have these tubes, and I have yet to find one that did not have at leat a 16" devatin in roundness and dia. over a 12" length ![]() This can cause problems if used to sand sides and such. especially if done before routing binding channels and using pilot bearings. |
Author: | RussellR [ Thu Mar 09, 2006 7:33 am ] |
Post subject: | |
I was warching a thing on TV a while back and some one was tring to sand mouldings, he rubbed a piece of pumice stone into the shape of the moulding and used that, maybe that could be useful in the headstock scenario, mind you where you get pumice stone I haven't a clue ![]() |
Author: | Daniel M [ Thu Mar 09, 2006 7:52 am ] |
Post subject: | |
I use erasers a lot, but I love the flip-flop idea. Off to the dollar store! |
Author: | Michael Dale Payne [ Thu Mar 09, 2006 7:53 am ] |
Post subject: | |
most hardware stores have it in there abrasive departments. use to clean grills. It, itself is abrasive |
Author: | npalen [ Thu Mar 09, 2006 7:55 am ] |
Post subject: | |
Back in my day they called them thongs rather than flip-flops. I suppose that is no longer "politically correct", however. |
