Router Feed Direction http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=5620 |
Author: | Sylvan [ Mon Mar 13, 2006 11:57 am ] |
Post subject: | |
Many years ago I learned what was probably the most valuable woodworking lesson I ever received. I learned it from a Zach Etheridge at Highland Hardware and it was about router feed direction. Just three words changed my thinking about routers forever.....Routers Go Left. Tonight I was reading about some members' router travails so I went and looked at Highland Hardware's site and, low and behold, they have actually written it up! Check out .http://www.tools-for-woodworking.com/ |
Author: | Anthony Z [ Mon Mar 13, 2006 12:32 pm ] |
Post subject: | |
Sylvan - I couldn't get the link to work - I think this is the link you meant. http://www.tools-for-woodworking.com/index.asp?PageAction=Cu stom&ID=3 |
Author: | Serge Poirier [ Mon Mar 13, 2006 12:34 pm ] |
Post subject: | |
i got it Sylvan, nice website for learning great tips on woodworking in general, thanks for sharing this! Serge |
Author: | Scott Thompson [ Mon Mar 13, 2006 12:42 pm ] |
Post subject: | |
Here it is http://www.tools-for-woodworking.com/index.asp?PageAction=Cu stom&ID=68 And the index page for the library http://www.tools-for-woodworking.com/index.asp?PageAction=Cu stom&ID=3 |
Author: | Brook Moore [ Mon Mar 13, 2006 2:09 pm ] |
Post subject: | |
I guess I don't totally agree with this as a simple rule. It is common cabinetmaking technique to move the router to its right, as then you are moving it against the direction of the bit rotation causing the bit to pull itself into the wood, and there is no danger of runaway movement. When using a router table, feeding in the equivalent direction of a left movement is usually warned against as being dangerous. Right movement also makes it more likely that the pattern is fully shaped. When you go to the left, the router is tending to pull away from the wood. Yes there are many times when it is useful to move the router to the left, for example it is a bad idea when routing end grain to go all the way to the corner moving right, as you risk a split-out. When routing something critical, which is pretty much everything in a guitar, I think the best technique is to move the router in whichever direction is "downhill" to the grain first, and maybe second, and then finish with the router moving to the right. |
Author: | Mattia Valente [ Mon Mar 13, 2006 6:19 pm ] |
Post subject: | |
We're guitarbuilders, we do a lot of things cabinetmakers find inasane and bizarre (witness all the cross-grain joints). But you're right; once you're 99% of the way there using the 'safe' cut (in terms of not tearing out, not in terms of the router not running away from you), you should do a full-circle with a normal cut to get things perfectly flush. |
Author: | KenMcKay [ Mon Mar 13, 2006 11:57 pm ] |
Post subject: | |
I don't quite get it! I read the article and It seems backwards to me. I have always cut with a router against the spin of the bit. In all of the woodworking articles I have read this is the first time I have heard of this. Sylvan, do you rout this way. How long did it take to get used to it? Do you rout the binding ledge this way? |
Author: | Brook Moore [ Tue Mar 14, 2006 2:03 am ] |
Post subject: | |
If you are facing a piece of wood, with an upright router in your hands, and are going to route the edge of the wood closest to you, then this is the perspective in which you can orient to the router's right or left. "Normal" direction is to the right, though with greater risk of tear-out. Climb cutting is to the left, safer as far as tear-out but tending to wander or "climb" away from the wood. This "wandering" can actually be fairly violent if using a big bit on a powerful router, something not done often on a guitar. |
Author: | Mattia Valente [ Tue Mar 14, 2006 2:56 am ] |
Post subject: | |
Brook, I think you're talking about something quite different to the author of that piece, namely you're thinking about what the bit is doing; he's boiled down the effect of what the bit is doing (regardless of climb or regular cut) on the entire router - it goes left relative to the direction its travelling. This isn't about the spin of the bit, s'much, although the spin is what makes routers want to go left; this isn't about climb cutting, or normal cutting, either, it's about understanding where the router wants to go: towards the left *within its frame of reference*. As in, to the left side of the direction you're pushing or pulling it in. It tells you where to put a fence, f'r instance. Sylvan told me this rule in person when I visited him, but it's taken a while to sink in fully. At least, I think it's sunk in fully. Sylvan, did I get that righ? ![]() |
Author: | Bruce Dickey [ Tue Mar 14, 2006 3:47 am ] |
Post subject: | |
Not yet. Huh? I route all the time and have probably done it right and wrong. So, left relative to the direction the router is moving? Corn fused. Grin. |
Author: | Sylvan [ Tue Mar 14, 2006 5:01 am ] |
Post subject: | |
Mattia - You are absolutely correct!!!!! Lesson well learned! Here is a quick way to deal with what the router wants to do in context of "Routers go left". Let's suppose you want to cut a slot in a piece of wood. You need to use a fence. Which side of the router does the fence go on? It all depends on which way the router will travel. Knowing that the router ON ITS OWN wants to go left, put the fence on the left side and the router will actually "hug" the fence with little or no effort from you, insuring a straight cut. When you get confused, here is the quick trick - using your right hand, palm down, point with your index finger in the direction the router will travel when making your cut. The direction your right thumb is pointing is where to put the fence. This also works for pattern cutting and bits with ball bearings. You want the router's action to hold the bearing to the work surface just as if it was a fence. Remember, in a router table the router is upside down. So, in a router table router's want to go right NOT left. Again, knowing this greatly facilitates patten routing since we all know that the fence on a router table is to the right of the work! |
Author: | Bruce Dickey [ Tue Mar 14, 2006 5:05 am ] |
Post subject: | |
Okay, I'm trying, then you gave me a new rule: The router always goes left, unless it's upside down, then it goes right, relative to me, but left relative to the router, right? |
Author: | Alain Desforges [ Tue Mar 14, 2006 5:10 am ] |
Post subject: | |
Great tip Sylvan! Another little tip/trick in my (expanding) arsenal of wood-working experience. Thanks a lot. |
Author: | Dave Anderson [ Tue Mar 14, 2006 7:24 am ] |
Post subject: | |
I think I've gottit guys. Thanks to all for this info. I'm just getting into routing so this will DEFINATELY help! Routers Go Left !! |
Author: | Brook Moore [ Tue Mar 14, 2006 10:15 am ] |
Post subject: | |
Well, I wondered how such strange advice could be given by Highland Hardware, and thought that I must be missing something - and I was, though it will take me some studying to "get it". The woodworking universe knows that routers "normally" are moved to the right, and after decades of looking at it that way, I literally could not follow what was being said in the article. I am not adverse to re-structuring my old mental processes, but it doesn't come easy. ![]() |
