Attaching patterns to shell/ inlay pic http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=5712 |
Author: | 1bordeaux [ Sat Mar 18, 2006 6:41 am ] |
Post subject: | |
Just wanted to share a tip on attaching patterns to shell. After trying many types of glue, I settled on non-toxic glue stick. Yes, the one your grade schooler used in arts and crafts! It's water soluble,inexpensive, and easy to find.(Just rob your kid's bookbag!) The trick is to coat your pattern and the shell blank. Let it dry for a minute and it's ready to cut. It also works well when sending cut shell to a customer on a backer. It will hold firm, yet release in under a minute submerged in warm water. Below is a recent "mirror image set" of inlays for Schwartz guitars. ![]() |
Author: | peterm [ Sat Mar 18, 2006 7:30 am ] |
Post subject: | |
Thanks for the tip!! Will try on the next one.... |
Author: | BlueSpirit [ Sat Mar 18, 2006 8:13 am ] |
Post subject: | |
Beautiful work, Paul! And a great tip. |
Author: | MSpencer [ Sat Mar 18, 2006 8:20 am ] |
Post subject: | |
Really nice, I am getting pretty convinced that the Art of Inlay is just that. These sponsors that do custom inlay work is starting to make more sense to me on some of my builds. I'm all in favor of the well rounded builder concept that learns all the aspects of guitar building, however, this as a stand alone art expression is pretty complex. Doing a little ditty here and there I am fair, but this level of quality above is unbelievable. Thanks Paul and our other Inlay sponsors for sharing this great work and talent you all have. I hope I can afford you expertise in the near future. Mike White Oak, Texas |
Author: | Mattia Valente [ Sat Mar 18, 2006 8:33 am ] |
Post subject: | |
Beautiful inlay! And thanks about the tip re: coating both sides. I've used glue stick with good success just applying it to one surface, but it tends to flake up if you only apply it on one face! |
Author: | tippie53 [ Sat Mar 18, 2006 9:02 am ] |
Post subject: | |
I must try that. I use water basd rubber cemenet john |
Author: | Serge Poirier [ Sat Mar 18, 2006 10:22 am ] |
Post subject: | |
awesome work Paul! |
Author: | Don Williams [ Sat Mar 18, 2006 10:46 am ] |
Post subject: | |
Wow! Paul that's gorgeous! |
Author: | Anthony Z [ Sun Mar 19, 2006 2:29 am ] |
Post subject: | |
[QUOTE=1bordeaux]After trying many types of glue, I settled on non-toxic glue stick. Yes, the one your grade schooler used in arts and crafts! ........ The trick is to coat your pattern and the shell blank. Let it dry for a minute and it's ready to cut.[/IMG][/QUOTE] Beautiful work Paul. I've been using CA to glue may pattern on shell blanks...and occassionally the edges of the paper pattern let go with the heat of jewellers blade. This doesn't happen with a glue stick? |
Author: | clavin [ Sun Mar 19, 2006 6:58 am ] |
Post subject: | |
I have been using 3M's Scotch super strength glue. It's a little goopy, but it's a one coat deal, and I have not found anything it doesn't stick to yet, all pearls, all metals, it doesn't heat up, it never lifts. I haven't given it the soapy water test, but I don't use that technique in my inlays. It does stay flexible long enough to peel or scrape off fragile pieces. I hear some people can't find it though. Nice stuff Paul! Very classy. I can't wait to see it after it's engraved. Craig L |
Author: | 1bordeaux [ Mon Mar 20, 2006 11:04 am ] |
Post subject: | |
[QUOTE=Anthony Z] Beautiful work Paul. I've been using CA to glue may pattern on shell blanks...and occassionally the edges of the paper pattern let go with the heat of jewellers blade. This doesn't happen with a glue stick?[/QUOTE] I had the same problem with CA; The only time it's happened since going to glue stick is when I've managed to not coat an edge. |
Author: | 1bordeaux [ Mon Mar 20, 2006 11:10 am ] |
Post subject: | |
[QUOTE=clavin] I have been using 3M's Scotch super strength glue. It's a little goopy, but it's a one coat deal, and I have not found anything it doesn't stick to yet, all pearls, all metals, it doesn't heat up, it never lifts. I haven't given it the soapy water test, but I don't use that technique in my inlays. It does stay flexible long enough to peel or scrape off fragile pieces. I hear some people can't find it though. [/QUOTE] Craig, I actually use the Scotch brand of glue stick when I can find it. |
Author: | Anthony Z [ Mon Mar 20, 2006 1:07 pm ] |
Post subject: | |
Thanks for your reply Paul -- sorry for having sounded dubious -- I will now certainly give it a try. |
Author: | Joe Beaver [ Mon Mar 20, 2006 2:40 pm ] |
Post subject: | |
You cut those by hand? It is a great job. Looks machine cut. I'll never be able to do that.... |
Author: | 1bordeaux [ Tue Mar 21, 2006 9:03 am ] |
Post subject: | |
[QUOTE=Joe Beaver] You cut those by hand? It is a great job. Looks machine cut. I'll never be able to do that....[/QUOTE] Joe, I was once told that I,"was not capable of cutting inlay", many years ago. That lit the fire under my hiney. Never say never... |
Author: | Joe Beaver [ Tue Mar 21, 2006 11:36 am ] |
Post subject: | |
Paul, You could be right. I think I just might take my next inlay more seriously. I'm thinking with more patience and care mine would be a little better... |
