Removing kerfing http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=5971 |
Author: | Rossy [ Tue Apr 04, 2006 2:53 pm ] |
Post subject: | |
Hey guys, I was wondering what the best way would be to remove kerfing. Got some real obvious joints. Thanks for the help. Ross |
Author: | Jim Watts [ Tue Apr 04, 2006 3:02 pm ] |
Post subject: | |
I've chiseled out sections before and then scraped the remaining glue/fiber away. Good luck. |
Author: | Don A [ Tue Apr 04, 2006 3:17 pm ] |
Post subject: | |
Ross, what kind of glue did you use? If it was titebond, you can use heat (blow dryer..it will take a while), work a knife under it at one of the joints and then use a piece of dental floss to slide along and seperate the rest as the heat weakens the glue bond. I've done this with a neck block with no problem, don't ask why. ![]() |
Author: | Rossy [ Tue Apr 04, 2006 5:33 pm ] |
Post subject: | |
Thanks guys. Yes Don I did use Titebond. I will give the hair dryer shot. I knew that thing taking up space in my drawer that my wife uses would come in handy some day. ![]() Thanks again! Ross |
Author: | Serge Poirier [ Tue Apr 04, 2006 10:30 pm ] |
Post subject: | |
Good luck with the fixin' Ross, let us know how it went! Serge |
Author: | letseatpaste [ Tue Apr 04, 2006 10:46 pm ] |
Post subject: | |
I had to do this a couple times before I got my linings installed right. I ended up giving up on reversed kerfed linings and going with regular. I found using a paint removing gun (not too expensive at Walmart) worked great. I also found that if you use stick a little screw driver into the kerf and twist as you heat, it'll help shear the glue joint. I found it much easier to do that than to pry or pull the joint apart. I posted about it here on my blog. ![]() On a different one, I had to chisel out and replace a section of lining after removing the back. Posted about that here. |
Author: | Rossy [ Wed Apr 05, 2006 1:39 pm ] |
Post subject: | |
Thanks guys. Once again, I appreciate all of your input and help. I'll let you know how it goes. Ross |
Author: | charliewood [ Thu Apr 06, 2006 4:48 am ] |
Post subject: | |
cool blog letseatpaste, I will definitely read thru it! Cheers Charliewood |
Author: | letseatpaste [ Thu Apr 06, 2006 5:55 am ] |
Post subject: | |
[QUOTE=charliewood] cool blog letseatpaste, I will definitely read thru it! Cheers Charliewood[/QUOTE] Thanks, Charlie. I mostly do it so I'll have an incentive to keep taking pictures and document my builds, and the accountability of knowing people are watching is a bonus (sometimes :). |
Author: | Serge Poirier [ Fri Apr 07, 2006 10:10 am ] |
Post subject: | |
Jon, i had missed your post about your blog, sure will look at it closer! Thanks ![]() |
