It is currently Tue Aug 05, 2025 6:14 pm
PostPosted: Thu Apr 06, 2006 10:44 am
I brought a couple of my guitars in to a shop today and they were well
received, but several of the guitar shop salespersons noted that my guitars
were heavy!!! Granted I used cocobolo on one of them, but they asked what
I thicknessed my backs and sides to. I typically go to about 0.085 to 0.09"
What do all of you do? Do you change thickness based on the type of
wood???
PostPosted: Thu Apr 06, 2006 10:52 am
Andy, .085 to .095 sounds about right to me! I try to stay around .090 and I'm sure it will end up a bit thinner after you're done sanding and scraping!!
PostPosted: Thu Apr 06, 2006 10:55 am
I tend to go thinner with cocobolo, more like .080" or so. It lightens it up a bit and helps the wood sound even better. Sides are a bit thin too.
PostPosted: Thu Apr 06, 2006 10:57 am
Andy, you are spot on. Especially for early guitars. When you've gotten the confidence that you can do successful bends every time you'll be able to go a tad thinner. I bend most woods right at .085 and then will go a bit thinner when truing up the sides. My backs are usually about .095.
PostPosted: Thu Apr 06, 2006 10:59 am
Mabe they are used to mahogany . Some of the other woods can be much heavier. Cocobolo is quite dense . I recently played an old L-00 it was like a feather compared to mine.
