Glueing Frets? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=6019 |
Author: | GregG [ Fri Apr 07, 2006 2:51 am ] |
Post subject: | |
I'm getting ready to fret my second guitar and was wondering if glueing them in is the norm....or just pess and be done! Thanks, Greg |
Author: | Michael Dale Payne [ Fri Apr 07, 2006 3:00 am ] |
Post subject: | |
It boils down to slot width to tang width ratio. |
Author: | Michael Dale Payne [ Fri Apr 07, 2006 3:27 am ] |
Post subject: | |
I guess I could explain a bit more ![]() |
Author: | GregG [ Fri Apr 07, 2006 4:39 am ] |
Post subject: | |
Thanks Michael, How do you widen the frets a tad? what do you use? Thanks, Greg |
Author: | Michael Dale Payne [ Fri Apr 07, 2006 4:57 am ] |
Post subject: | |
I use an exacto backsaw blade that cuts a .028" kerf. It is a china made saw blade(an Exacto hobbie knife-saw knock-off). I use StewMac's Med/Med fretwire. Standard dry fit kerf for it is .023" so this enlarges the kerf by .005" |
Author: | EBarajas [ Fri Apr 07, 2006 7:03 am ] |
Post subject: | |
I use a fret barber from stewmac and thin out the tang a bit then I press them in the slots and wick in some ca. This method I think is really the best of both worlds, 1st off you don't get too much back bow in the fingerboard when pressing them in and 2nd you still have a nice tight fit between the tang and the slot. I build mostly classicals and I changed from fretting on the neck to fretting the fingerboard before it's attached. I then sand the sides of the neck flush to the sides of the fingerboard using a robosander indexed off the fingerboard side as a template, works great! An added benefit is I can bevel the edge of the frets before it's on the guitar and that keeps the guitar from possibly getting scratched or damaged. ![]() |
