A regular planer to thickness
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=6258
Author:  bbeardb [ Thu Apr 20, 2006 3:48 am ]
I haven't heard of anyone using a regular planer to thickness backs or sides. What is the reason for this? Please tell me before I run something through my planer and find out the hard way.
Author:  Don Williams [ Thu Apr 20, 2006 4:26 am ]
A planer will shred thin wood into little chunks.
Trust me...
Author:  Don Williams [ Thu Apr 20, 2006 4:29 am ]
What happens is when the knives start hitting the wood, because it is so thin it starts springing around and gets chewed all to heck.
Do not even think about attempting it...
Author:  tippie53 [ Thu Apr 20, 2006 4:31 am ]
IT DON"T WORK ! DWilliams is telling the truth. A thickness sander is the tool Once you get below 1/4" you are too think for any power planer. I heard C Holden got a jig for thinning plates.
john hall
Author:  bbeardb [ Thu Apr 20, 2006 4:33 am ]
What if you could control the speed rate of your planer and run the stock through slowly?
Author:  A Peebels [ Thu Apr 20, 2006 4:38 am ]
I've done it with mixed results, and I don't recommend it.On fairly straight grained Palo escrito, I used doubleside tape to tightly hold it down to a carrier board. You have to carefully consider the direction of the runout to keep it from grabbing and taking out chunks. Anyway it worked until I tried some figured wood. The side suddenly exploded and scared the heck out of me. I still use my planer, but never below @ .200" and then only with great care and only on straight grained wood.
My planer gets used mostly for cleaning up one side of boards between cuts when resawing, and for thicker wood. Bottom line it's just not the right tool for the job.
AlA Peebels38827.5724189815
Author:  charliewood [ Thu Apr 20, 2006 4:40 am ]
You will have some pretty expensive toothpicks thats what,
Charliewood
A wagner SafeT is pretty cheap -
Author:  Joe V [ Thu Apr 20, 2006 5:46 am ]
I tried it too, against the advice of those who knew better. I'm glad I did it with orphaned sides. It tore some nice chucks out.
Joe
Author:  rich altieri [ Thu Apr 20, 2006 10:49 am ]
Been there done that. Some time ago. Was working great at first and I was thinking - "What's the big deal here? Must be these Luthier fellows never thought of this!! Must be they are stuck in tradition! Boy am I smater than the average bear?" And then on one pass I heard a bang and out the end of the planner came my back busted into a few pieces. That was one expensive lesson.
Author:  Howard Klepper [ Thu Apr 20, 2006 2:07 pm ]
I don't have a problem going thin with my 20" Grizzly, unless the wood is
curly figured. I usually play it safe with back and side woods and don't try to
go under about 3/16" on the planer, but with spruce I have no problem
going close to 1/8"
Author:  tippie53 [ Thu Apr 20, 2006 2:51 pm ]
    I have a grizzly 15 and the trouble is once you get the wood much below .250 it is too floppy and with the knives turning into the wood , you will blow up the piece. Yes you may get lucky once in a while but trust me , why take a chance to ruin a $75 set of wood ?
      If we could train termites just think what we could do
john hall
Author:  j.Brown [ Thu Apr 20, 2006 4:48 pm ]
Yep. Too floppy and it bangs around and will just blow up. The Saf-T-Planer is really the best way I've found without the use of a drum sander.
-j.
Author:  bbeardb [ Fri Apr 21, 2006 1:53 am ]
Alright, I'm sold, or un-sold, however you want to look at it. I'll pass on the planer. But I'm sure I'll give it a try if I ever have some scrap laying around. It's just tempting, because I have the planer, but no Wagner, and no drill press...
Author:  Howard Klepper [ Fri Apr 21, 2006 4:55 am ]
I just report the news from my shop. You don't have to believe it.
Never hurts to play safe with abrasive planing, though. If you are going to
have just one of these machines, get the sander.Howard Klepper38828.5818171296
Author:  Don Williams [ Fri Apr 21, 2006 5:01 am ]
[QUOTE=tippie53]If we could train termites just think what we could do
john hall[/QUOTE]
ROFL....that is Brilliant !
That's worthy of quoting !
                                   Don Williams38828.5863541667
Author:  ctholden [ Fri Apr 21, 2006 12:21 pm ]
[QUOTE=tippie53]   IT DON"T WORK ! DWilliams is telling the truth. A thickness sander is the tool Once you get below 1/4" you are too think for any power planer. I heard C Holden got a jig for thinning plates.
john hall[/QUOTE]
Yup John, I do. It uses a router to thickness a board up to 20" wide by 36" in length, so you can thickness tops, sides, and backs. My customer feedback measures it within 10 thousandths of an inch.
Craig
CT Holden Luthiery and Supplies, Inc.
Author:  D.L.Huskey [ Fri Apr 21, 2006 11:23 pm ]
I have used double sided tape to attach the piece to be thinned to a backer board and ran the whole thing through the planer. It works pretty well.
Author:  Kevin Gallagher [ Sat Apr 22, 2006 5:29 am ]
    Thin quartersawn exotic woods + a planer + expensive sawdust !
    It will destroy your wood 9 out of 10 times.
Regards,
Kevin Gallagher/Omega Guitars
