X brace cut depths http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=6412 |
Author: | Rossy [ Fri Apr 28, 2006 1:54 pm ] |
Post subject: | |
Guys, Just wondering how deep the cuts into the X braces should be to join together if they're about .700 tall. Thanks. Ross |
Author: | L. Presnall [ Fri Apr 28, 2006 1:57 pm ] |
Post subject: | |
Ross, in theory .350, half of the depth of each member... |
Author: | Rossy [ Fri Apr 28, 2006 2:00 pm ] |
Post subject: | |
Thanks Larry! You da man! Peace |
Author: | peterm [ Fri Apr 28, 2006 2:01 pm ] |
Post subject: | |
Half is what I use too ![]() |
Author: | burbank [ Fri Apr 28, 2006 2:21 pm ] |
Post subject: | |
Half and......... half! ![]() |
Author: | ecklesweb [ Sat Apr 29, 2006 12:31 am ] |
Post subject: | |
I actually don't measure for a lap joint like that. I mark and cut the first one at what looks like half the height, and make the cut on the brace from the top first. Then, I line up the bottoms of the two braces and use the bottom of the first cut to mark the other brace. Cut from the bottom of the other brace to that mark. If I've reconstructed this correctly in my mind, that should ensure that the lap joint has the bottom of each brace perfectly flush. Ergo, this method also works with braces that are not the same height. (I'll rough my braces out, join them, and then plane the taller one down to meet the top of the shorter one, glue a cap on (per suggestions here), and then carve. DISCLAIMER: Mind you, this all comes from someone who's first acoustic guitar is still in unassembled pieces on his workbench! But, I have done quite a bit of furniture building, so I'm comfortable talking about joinery in general. |
Author: | Bill Greene [ Sat Apr 29, 2006 1:41 am ] |
Post subject: | |
That is exactly how I did it...although darn if I could have worded it as well. And it fit very tight. It never dawned on me to just to half/half. |
Author: | L. Presnall [ Sat Apr 29, 2006 3:37 am ] |
Post subject: | |
Yep! It is, after all just a half-lap joint that happens to be on a slight angle...in fact, the angle is harder to execute than the "lap" itself! |
Author: | Rossy [ Sat Apr 29, 2006 7:02 am ] |
Post subject: | |
Thanks again guys and Jay I think I'll try it that way. Late. Ross |
Author: | TonyKarol [ Sat Apr 29, 2006 7:55 am ] |
Post subject: | |
I cut mine half way plus a hair on the table saw, setting the mitre gauge to the correct angle. Couldnt be easier. |
