It is currently Mon Aug 11, 2025 12:56 am
PostPosted: Tue May 02, 2006 11:42 pm
Check out this site. Dental Burs USA
They have all sorts of dental bits for cheap. Only $1.50 each. Plus they have a nifty size chart so that you can get the size and type of cut you want.
This might even be better than visiting your dentist...although everyone should visit their desntist a couple times a year.
PostPosted: Tue May 02, 2006 11:46 pm
I've heard of using detal burs in a dremel for lutherie, the only thing I
can't figure out: what do you use them for!!! Let me in on the secret...
PostPosted: Tue May 02, 2006 11:56 pm
I bet they would work pretty well for detailing and cleaning up inlay work. Some of those bits are quite thin. Other than that, I guess if you ever plan to giver yourself a root canal, you have everythign you need.
Cheers!
PostPosted: Wed May 03, 2006 1:23 am
Jay, Some of the guys use them to rout out inlays. They are a lot cheaper than comprable dremmel bits and they come in smaller sizes so that you can get finer detail.
PostPosted: Wed May 03, 2006 1:33 am
I get free ones from my dentist they are used but are fine for inlay work but can not be reused in denistrie due to infection concerns.
PostPosted: Wed May 03, 2006 5:27 am
[QUOTE=JBreault] Check out this site. Dental Burs USA
They have all sorts of dental bits for cheap. Only $1.50 each. [/QUOTE]
Checked it. Minimum order of 50 bits + $6.50 shipping.
PostPosted: Wed May 03, 2006 6:12 am
First name: Coe
Last Name: Franklin
City: Decatur
I can do ya better, gang. 5 bucks, 6 bits. No shipping. PM`s only, please.
PostPosted: Thu May 04, 2006 6:59 pm
I use them on a precision dremel base, to clean the fret slots during a refret, saves a ton o time.
PostPosted: Fri May 05, 2006 3:14 am
First name: Coe
Last Name: Franklin
City: Decatur
Gtrplry1, do you use a jig setup, or can you just follow the slots freehand? Just wondering.
