loosening cyanoacrylate?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=6533
Author:  peterm [ Fri May 05, 2006 5:22 pm ]
Well, here's the story:
My last 2 guitars have been fitted with a pinless bridge design kinda like Elliot guitars invented, with rod pins that let the string end balls hook on to. Unfortunately last night I wasn't paying to much attention (again ) and pushed one of the pins in too far down and its too low to be able to hold the string in place if I could get a good grip on the rod I would try to twist and pull it out but that its not the case. too little room in there I was thinking if I could some how loosen the CA that holds the rod in place I could just push it thru and that would be it!
the question is: does any one know of a good way to loose the CA without damaging the bridge? please?
Any help would be more than welcome
Thanks in advance
Author:  crowduck [ Fri May 05, 2006 5:35 pm ]
I think acetone will dissolve CA. Maybe try to 'wick' some in by the rod with a pipette while pushing. Be carefull not to drip it on your finish if it's dissolved by acetone, maybe mask off your soundboard. An icepick might be a good tool to push the rod.....grind the sharp point down.
CrowDuck
Author:  Mattia Valente [ Fri May 05, 2006 6:11 pm ]
I'd personally apply a soldering iron (a CLEAN TIPPED one that's NOT tinned), and push on through.
Author:  crowduck [ Fri May 05, 2006 8:02 pm ]
Peter,
Yeah, try what Mattia said, I forgot about that one. If the tip is 'tinned', get it hot and wipe it clean with a wet sponge or cloth.
CrowDuck
Author:  peterm [ Sat May 06, 2006 2:50 am ]
Yup, I should try the soldering iron! I'll wait to see if anyone else comes up with any other idea!
Author:  Serge Poirier [ Sat May 06, 2006 3:02 am ]
Good luck with the fixin' Peter, i also think Mattia has it with the soldering iron, let us know how it goes buddy!
Author:  peterm [ Sat May 06, 2006 3:50 pm ]
Thanks guys! the soldering iron did the trick! God Bless the OLF!
Author:  Serge Poirier [ Sun May 07, 2006 11:24 am ]
Very happy to hear that Peter! WTG!
Author:  Michael Shaw [ Sun May 07, 2006 11:27 am ]
Hey! Nail polish remover works also.
Author:  Billy T [ Mon May 08, 2006 9:38 am ]
[QUOTE]Hey! Nail polish remover works also.[/QUOTE]
Nail polish = Acetone + soap + fragrance + coloring.
Good thing I took all that math in the second grade! Paying off big time now!
