It is currently Wed Aug 13, 2025 3:55 pm
PostPosted: Fri May 19, 2006 4:12 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Hey Gang:
I'm about to build a bridge shaping and drilling jig using John How's excellent tutorial in the Jigs section. What is the standard size for drilling the pin holes? I'm gonna go buy some drill bushings and want to make sure I get the right size. I'm building dreads if that makes any difference.
Thanks in advance!
-Mark
Mark Tripp38856.5579861111
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Fri May 19, 2006 4:19 am
I think it is 3/16". But I'm not 100% sure.
PostPosted: Fri May 19, 2006 4:24 am
I use the 3/16 bushings (available @ LMII) and they work fine for most pins however check your pins first as you don't want the hole too big. You still have to taper them with a reamer. Usually I'll just get a couple turns of the reamer to get a good fit of the pin in the hole.
PostPosted: Fri May 19, 2006 4:30 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Thanks guys!
Checked the size I'll be using, looks like 3/16 will be the ticket.
Thanks again!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Fri May 19, 2006 9:41 am
John:
Did I read here once that you no longer use this system? If so, can you elaborate on why. Thanks.
Bill
cron
