It is currently Mon Aug 11, 2025 4:53 pm
PostPosted: Thu May 18, 2006 2:04 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I have heard that Robert Johnson's L-00 had a sunbust top. True?
How do you do a sunburst?
PostPosted: Thu May 18, 2006 2:21 am
If your referring to the guitar pictured on most of the recorded volumes of Robert Johnsons work, it is a Gibson L-1. Sunbursts can be rubbed on with stains (hard to get consistent results though) or sprayed directly on the wood (the way I do it) or shaded in the finish (the way most do it).
PostPosted: Thu May 18, 2006 8:24 am
Last Name: Johnson
State: CO.
Thank you John,
How about air brush?
Do you know if there is a step by step set of instructions with pictures?
PostPosted: Thu May 18, 2006 11:03 pm
Last Name: Johnson
State: CO.
Bump
PostPosted: Fri May 19, 2006 6:46 am
Bob,
If you can find a copy of Roger Siminoff's book Building a Bluegrass Mandolin, it has a good demonstration of the hand application of a sunburst on bare wood. He uses alcohol-based dyes, which can be blended on the wood better than could water-based, but that eliminates the possibility of using shellac as a sealer or finish.
As for spray application, I'm sure Stew-Mac has an appropriate book and/or video explaining the process.
PostPosted: Mon May 22, 2006 12:51 am
Last Name: Johnson
State: CO.
bump
