Tips on style 42 inlay http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=6827 |
Author: | Louis Freilicher [ Tue May 23, 2006 8:51 am ] |
Post subject: | |
Hi all, I'm planning on building an OM-42 style guitar this summer and I wanted to ask for any tips / hints on inlaying the mitered pearl and purflings around the fingerboard extension. Thanks, Louis |
Author: | tippie53 [ Tue May 23, 2006 10:20 am ] |
Post subject: | |
actually this is very simple. I use abalam but the techniques are the same for solid pearl. Use a teflon fill strip and you use that when binding. When you are ready to put in the pearl you lift the poly out and start laying the pearl. I use elmers white glue then once I am done I will drop fill with CA to fill voids in the pearl john hall PS to cut the miter i use a fine 2nd cut mill file after I use a toe nail clipper to cut to aproximate length. Clipper was never used on toes |
Author: | Louis Freilicher [ Tue May 23, 2006 10:44 am ] |
Post subject: | |
Thanks for the tips John. When you rout the slots around the fingerboard for pearl / purfling do you undercut the whole fingerboard extension area and fill the gap with an ebony veneer? Thanks, Louis |
Author: | tippie53 [ Thu May 25, 2006 8:46 am ] |
Post subject: | |
HI Yes I do . This allows for future repair and adjustments at neck set time if need be |
Author: | Louis Freilicher [ Thu May 25, 2006 8:51 am ] |
Post subject: | |
Thanks again John! Louis |
